One-way diff slipping........HELP!!! >
Old 05-10-2007, 01:51 AM
  #16
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Use the specific One Way lube, Serpent and X Ray make it. Don't be putting other s#it in there, I did that once, cost me the one way! Best to spend the $7-$8 and do it right!
nexxus is offline
Old 05-10-2007, 03:03 AM
  #17
Originally Posted by Tpg racer
Would it be ok if I were to put some glue on the shaft so that the bearing wud stick to it instead of slipping???
put some glue on it would convert the one-way into Spool..
last things you may try, put some thick/heavy grease on internal of outdrive
if it fails, IMO, once it slippin out then no other way to salvage it (one-way bearing),
have you see internal inside the right side outdrive (one-way bearing sit inside it) ?
if it is not damaged (..some tiny cylindrical bearing fall out and plastic cage shattered...) then probably it is worn out due to lack of lubricant..
One-way need specific lubricants (serpent one-way lube on my car) and proper maintenance..
Faiz is offline
Old 05-10-2007, 07:05 AM
  #18
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Big B
Try taking it apart and rebuilding, replacing all the parts with wear, and rebuild with a good lube and replace the blades (if you have them) on the Cvds
Originally Posted by ShrekNZ
Yep get some one way lube and lube the one ways after cleaning they are probably gunked up and not locking up.
Light oil will probably also suffice - not grease
After reading all the posts. Big B & ShrekNZ gave you the logical/obvious choices. Just clean with motor spray and relube with oneway lube.
grease or glue. These recommendations must be from the guys you are beating at the local track.
F. Mendoza is offline
Old 05-10-2007, 07:28 AM
  #19
Tpg racer's Avatar
Yo guys I've manage to resolve the problems right away.....turns out its the one-way bearing being faulty........I jz sprayed WD-40 a couple of times inside the diff and oil it up with some bearing oil.....and the problem seems to have gone.......
What a relief........
Tpg racer is offline
Old 05-10-2007, 12:22 PM
  #20
Big B's Avatar
Great. By the way what chassis are you running? If you still want help taking it apart I am sure one of us can help you with your specific chassis and one way.
Big B is offline
Old 05-10-2007, 09:21 PM
  #21
Tpg racer's Avatar
I'm running a Pro 4...
Old 05-10-2007, 10:44 PM
  #22
Big B's Avatar
Here is the page out of the Manual
Big B is offline
Old 05-11-2007, 01:19 AM
  #23
Tpg racer's Avatar
Thnx Big B, but I already have the manuals.......its useless as it did not mention anything about lubricating the bearings and so on.......
Old 05-11-2007, 01:32 AM
  #24
nexxus's Avatar
Replace part 75111 if no fix, replace 75140.
nexxus is offline
Old 05-11-2007, 02:59 AM
  #25
Tpg racer's Avatar
Dont worry its all fixed up good...
Old 05-11-2007, 05:10 PM
  #26
James khoo's Avatar
Trader Rating: 15 (100%+)
Never use bearing oil on your oneway!it will make the drive cup slip when operate,the one way is design to lock when the front tire speed is faster then rear!use proper lube,like oneway grease,oneway lube or car auto transmision oil,just go light on lube(it will not atract dirt).this will do,the oneway will last you for years
James khoo is offline
Old 05-12-2007, 08:10 AM
  #27
Tpg racer's Avatar
Yo James, my bearing oil is from my car oil.........
