How can you tell when a rubber tire is worn?
How can you tell when I rubber tire is worn? Or when it is time to change the set of tires?
I personally run cs27, because of the availabilty at my local hobbyshop.
Any input of info is much appreciated.
till they wont grip anymore is when i toss them and thats with tire traction
The tyre is black when you buy it, use it until it turns a shade of grey. You should know the grey colour as it is the colour of canvass, wait until all the grey is even and then bin it, or, another way is when the rim shits itself
Thats the way we do it downunder
AUSSIE BOB
AUSSIE BOB
AUSSIE BOB
AUSSIE BOB
you know your tyres are gone when you start grinding the rims to dust, and when the negetive ground clearance scrapes through the chassis into your batteries... my mentality is a little TOO tight budgeted...
It depends what surface you are running on. On carpet, if you are on a tight budget you change when a groove on the inside of the tire occurs. If you have money to throw around, when the middle molding line wears down.
only one sure way: lap times, they go down you need new tires
Originally Posted by HVFracingwilly
Yeah like you know, you have picked tires out of the trash that I threw away!!!
Tonight!
