64 or 48 pitch
gentlemen, for
on road touring what would u guys recomend as going to run in hpi pro 4 with a 540 motor on road touring. thanks. minnesh |
48 pitch is more durable. 64 is smoother. You can run either, but I personally would run 64 when your racing.
thanks guys
thank u
Originally Posted by minnesh
thank u
I also prefer 64 pitch but you have to be carful when meshing because there is not much room for error with them.
64 pitch :nod:
Charles |
suggestions
any good suggestions on brands or makes
thanks |
Xenon racing spurs and pinions :tire:
Charles |
64p if you are willing to spend $70 on pinions. 48p if you only want to spend $20 on pinions.
How do you figure?
48p:
http://www2.towerhobbies.com/cgi-bin...&I=LXEX34&P=ML and http://www2.towerhobbies.com/cgi-bin...&I=LXEX35&P=ML $22 for a complete set (12pcs) VS http://www.speedtechrc.com/store/ebp...?catmainid=467 $72 for a complete set (12pcs) |
your also comparing speedtech to towerhobbies, my 64P pinions cost average of 5$ per pinon
khoff, $5/pinion is the cheapest I've seen 64p at, and even that price isn't easy to find. What's your source?
Personally, I started with Robinson Racing set of evens 48p. I'm slowly switching to 64p, as I find used ones at $2/pinion. |
I find my 48 pitch pinions noisy, specially when using smaller teeth #. while 64pitch are very silent and smooth. I still go for 48p theyre durable. :)
64 pitch for carpet and asphalt racing, 48 pitch for offroad / dirt.
