Old 05-06-2007, 03:50 AM   #1
Tucker101's Avatar
Send a message via MSN to Tucker101
Default LRP?
Im getting a new car and im gonna need a motor and speedy and radio set, and am looking at some good equipment but i want the power first so i was wondering wether the LRP Sphere with 5.5 Turn motor is any good? give me some feed back yall
Tucker101 is offline   Reply With Quote
Old 05-06-2007, 07:46 AM   #2
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Go with one of these. I don't know your budget but this is the way to go.
The Novak systems have a wide variety of compatibility with a wide variety of motors. You just cant go wrong with the Novak systems.
http://teamnovak.com/products/brushl...ors/index.html
http://teamnovak.com/products/esc/gt...rum/index.html
http://www.horizonhobby.com/Products...odID=JRP374075
UN4RACING is offline   Reply With Quote
Old 05-06-2007, 09:15 AM   #3
Tech Legend
Wild Cherry's Avatar
Buy
Both, cus they offer the best performance you can buy for your money...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-07-2007, 02:01 AM   #4
Tucker101's Avatar
What are your thoughts on the LRP Sphere And Vector X11 5.5 Turn Motors, ive heard they are awesome but i need more convincing and they look awesome but how do they compare to the Novak systems?
Old 05-07-2007, 08:08 AM   #5
Tech Legend
First !
Both Novak and the Lrp...
Are great performing system`s ...
Lrp Competition ESC
* fewer wire`s and does not require a fan ....
*smaller and easier to fit in your ride
*easier to switch between brush and brushless (auto detect)
* Li-Po cutoff standard
The 5.5 X-11 is hand wound and has oversize ft bearing...
George W. Cherry
Old 05-07-2007, 10:30 AM   #6
Company Representative
Novak GTB/Velociti 5.5T System features:
~GTB has built-in lipo detection circuitry
~GTB is offered in Spread Spectrum version
~GTB has gasketted, water-resistant case
~GTB wires are external and user-replaceable
~GTB has reversible profiles
~All VEL/SS Pro motors have sintered rotors (not bonded like 5.5T X-11)
~Over-sized front bearing
~All motors factory hand-wound in CA
~Rotors and end bells are user-replaceable
~Motors protected vs thermal overload when used with GTB
~GTB/Vel 5.5 System includes fan and power trans-cap module, at no extra charge.
NovakTwo is offline   Reply With Quote
Old 05-07-2007, 02:45 PM   #7
Stein Tumert's Avatar
The LRP Sphere Competition TC spec works really well. Highly recommended.
For the top guys as well. Check the results from the TCM Masters end of April.
In the A final, 8 of the 10 drivers used this speedo... including Paul Lemieux.
http://www.lrp-electronic.de/tcm2007...Masters_fv.pdf
http://www.lrp-electronic.de/tcm2007/
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 05-07-2007, 02:53 PM   #8
bxpitbull's Avatar
Default The only reason....
It's the footprint of the GTB and wire assembly that is causing people grief. If some folks would take a few extra minutes, they would pick the GTB over LRP any day of the week! No need for a fan? Please. Anything that uses a heatsink can benefit from a fan. Does anyone complain about Hara running a fan on his motors? Or Losi with the double fan on their JRXS? Only when Novak does something do the complaints surface. Well poof you haters. My Novak GTB/3.5 rules! Ran with 1/8 scales this past weekend and came in third in a 30 minute race. I dare one of you cats to TRY that with any LRP set-up!
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 05-07-2007, 07:46 PM   #9
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default GTB
Go with all Novak GTB. The sphere's footprint is nice and the wiring is cleaner if you need to run brushed motors.
But LRP's quality and US customer service is way below par (not sure how your C.S. is over in AU).
I've been thru two spheres comp 07s, 1 burned out a 13.5 motor (same gearing as a GTB setup) the other 1 bad material, purchased at the same time so probably made in the same batch.
Not one of my past GTBs had quality issues (I've had 3).
I'm not sponsored by anyone or have any mfg hookups...my pocket speaks for me.
olhipster1 is offline   Reply With Quote
