MOTOR COMMS
Old 05-04-2007, 07:18 AM
  #16
Charles Godwin's Avatar
You can re-serrate them by using a 're-serrater' . Something like this from MuchMore or another company. You attach the alum plate to a old motor and the serrater bit to the shaft (like a pinion) then run the motor at about 3v, put the brush in the correct slot then push the brush against the serrator bit till the brush face has it's serrated face back.
Charles
Charles Godwin is offline
Old 05-04-2007, 07:02 PM
  #17
16skyline's Avatar
I have just done a cut on my new team brood stock motor. It was reving at 19500rpm at 4v when I finished cutting the com and put new brushes in the revs dropped by about 1300rpm someone please help, I even tried two types of solder HELP ME PLEASE.
16skyline is offline
Old 05-04-2007, 07:12 PM
  #18
trjracing's Avatar
Try fresh brushes and brush springs. If all else fails it could be the motor can magnets are getting weak.
trjracing is offline
Old 05-04-2007, 07:15 PM
  #19
trjracing's Avatar
It could be time for a new motor.
Old 05-04-2007, 07:16 PM
  #20
trjracing's Avatar
How many runs you put on this motor?
  #21
16skyline's Avatar
It is a brand new motor, it has only 2 pratice runs with it
Old 05-04-2007, 07:19 PM
  #22
trjracing's Avatar
WOW, It's surely new. When you rebuild the motor are you over tightening the endbell screws??? Are you shiming the arm properly???
  #23
You might not have the bit lined up correctly on your lathe. The bit might be to high.
SRW141 is offline
Old 05-04-2007, 07:21 PM
  #24
What type of motor is it? co27 or kd19
SRW141 is offline
Old 05-04-2007, 07:24 PM
  #25
If you are re-serrating the brushes make sure you clean the face of them with a com stick before serrating. Over tightening like was said is also not good.
SRW141 is offline
Old 05-04-2007, 07:27 PM
  #26
trjracing's Avatar
I'm with you on that.
Old 05-04-2007, 07:30 PM
  #27
16skyline's Avatar
Not sure what type of motor it is has a team brood pro sticker and it i a black can, The lathe was bought of ebay as I had the integy 2000 a bit hard to work with so i bought the 2000k with the diamond tip, this was already installed all i done was plug a battery to it, the lathe bit has a thin bit of cardboard under it also.
Old 05-04-2007, 07:32 PM
  #28
16skyline's Avatar
I didn't put any extra shims in than what it came with.
  #29
trjracing's Avatar
Also try using a brush alignment tool it helps alot.
Old 05-04-2007, 07:33 PM
  #30
trjracing's Avatar
OK... Let's see what else we can do to get your motor running 100%
