Lipo on brushed esc >
Lipo on brushed esc
Lipo on brushed esc
Old 05-03-2007, 08:50 AM
MrUnlimited's Avatar
Default Lipo on brushed esc
Is this possible? I only have people using lipo's on brushless esc. Anyone?
MrUnlimited is offline
Old 05-03-2007, 08:55 AM
Trader Rating: 38 (100%+)
Yeah its not a problem. You usually hear them together b/c people with brushless and lipo are early adopters of new technology. Just make sure you either use a ESC with lipo cutoff, add lipo cut off, or just take the car off the track when it slows down as to not over discharge your battery.
or8ital is offline
Old 05-03-2007, 08:56 AM
rampal's Avatar
As a short: Yes....
I've been using a pair of Orion 4800 with my VFS-1 Pro and Revolution 12x2. Amazing punch I would say.....
rampal is offline
Old 05-03-2007, 09:04 AM
Cool, how much runtime could I expect from a Orion 3200mah carbon with a 19T Checkpoint motor I know it depends on your gearing but what runtime could I expect?
Old 05-03-2007, 09:06 AM
I run the new Mtroniks IP6 esc in my car.
Patriiick's Avatar
No problem whatsoever on any esc with any motor.
With a 3200, with the correct gearing, expect about 30 secs less than with a good nimh 4200.
Patriiick is offline
Old 05-03-2007, 09:27 AM
Rick Hohwart's Avatar
I actually experience slightly longer run times with the Carbon 3200 versus my IB4200. These are results from a 7 turn brushed motor at Tamiya USA's facility.
Rick Hohwart is offline
Old 05-03-2007, 11:35 AM
Even cooler Rick I run a 19T Checkpoint motor so I can expect to run a 24 hour race on a single battery Just kidding I'll be running this with a new Mamba 7700KV in the near future in my Yokomo LCG
Old 05-03-2007, 11:41 AM
asw7576's Avatar
Really that good ?
I thought Carbon 3200 will not make it 5 minutes with 7T ( ......lets say I still make two or three mistakes during 5 minutes racing ).
I am considering Carbon 3200 ( lightweight ) but 4800 ( heavier ) is safer for accepting driver mistakes, Plus it is safer for low voltage situation..... lets say I test my car for 5min 30sec period ?
BTW: Are you Rick Howart from USA RC magazines ? cool !! Nice to meet you
asw7576 is offline
Old 05-03-2007, 11:50 AM
Originally Posted by asw7576
Really that good ?
Yes it is me
If you were to take the tp 30 drivers inthe world, they are all capable of turning nearly the same lap times. But I estimate there can be as much as a minute difference in run time among the same group. So even if I can make 5 minutes, someone else may not.
That is why giving an actual run time is not very precise. Every driver, car, and track is different. Thatis why I say that you get about the same or a little more runtime with the 3200 over the IB4200. If you are dumping with a 4200, you will probably dump with a 3200.
The one thing about LiPo is that there is no margin for error. If you have a bad run with crashes or you have to drive hard to make up time, you risk dumping (just as with 4200). But once your car begins to slow, you MUST stop. So you can be 1/2 lap from the finish and have to take a DNF. With NiMH, you can creep around the track, barely moving, and finish if you want.
The 4800 is a better choice if you can afford it and it is allowed. The idea behind the 3200 was to:
Make a battery that fits in most cars with little or no modification.
Keep the initial price close to that of the best NiMh batteries available.
Keep the capacity below the limits generally accepted when not using ROAR or IFMAR rules.
Old 05-03-2007, 11:59 AM
asw7576's Avatar
Allright !!! Thank you so much for your tips !!!
I guess I buy 4800 series.
asw7576 is offline
Old 05-04-2007, 08:46 AM
Orion is so far the only who makes a specific lipo fro cars but in Europe here we're going to race 5cells, in Japan they're going to race 4 cells and the US? With so many different rules I don't know if there is a feature for lipo's unless they are developing new ones.
Old 05-04-2007, 02:55 PM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
The club feature.
UN4RACING is offline
Old 05-04-2007, 03:33 PM
Iceracer's Avatar
It works just fine. I am running a stock 27 turn motor off 3200 orion lipos and there is about 20 minutes of run time. As I'm sure you already know, over discharging a lipo battery is bad for the cells, and potentially dangerous. The car will slow significantly before you overdischarge it, the voltage dropping from over 7.4 volts to 6 volts. I know this from watching the performance of my other vehicle that has lipo cut off at 6 volts, it does slow noticeably before the cutoff kicks in.
You can protect your cells by buying a Novak cutoff circuit for around $20-$25.00 so that your esc won't overdischarge the lipo cells. Tower and other sources have them.
Iceracer is offline
Old 05-04-2007, 09:03 PM
flying G.E.O.'s Avatar
Anyone notice that stock motors get hotter when using lipos than nimh? Not sure if the voltage and very linear discharge curve has anything to do with it. It also seems soft compared to nimh in stock. Lipos seem better for mod.
flying G.E.O. is offline
