Old 04-10-2003, 01:45 AM   #1
davioh's Avatar
Default unknown motor
hey everyone...my sister's boyfriend gave me some of his r/c stuff and there was a motor....im not sure how many T's it is...so im seeing if u guys know
it's a integy spin icarex v5.0....
heres a pic...1 of 2
davioh is offline   Reply With Quote
Old 04-10-2003, 01:46 AM   #2
davioh's Avatar
2 of 2
Old 04-10-2003, 04:42 AM   #3
j0n0's Avatar
Send a message via ICQ to j0n0
try focusing the camera on the motor hehehe
but seriously take the armatrue out of the can and it might have the wind printed on the armature.
good luck !
j0n0 is offline   Reply With Quote
Old 04-10-2003, 05:11 AM   #4
davioh's Avatar
hehe...my digi cam doesn't focus...wait...wuts the armature? the thing you pull out? well...i just don't wanna blow my ESC...i mean...i dun't think it will...it's a futaba 600c...so just in case...rite now i hav xspeed kyosho stock 11t on my car...might wanna go a bit slower for technique practice then switch to the fast one for speed.
Old 04-10-2003, 06:08 PM   #5
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: unknown motor
The Can looks like it's based of a Tamiya one..it has similar lower cooling vents as my 23T RR
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-10-2003, 10:05 PM   #6
davioh's Avatar
23 T??? damn...it seemed faster than my 13 T though...hehehe....anyone knows who has this motor?
Old 04-10-2003, 10:49 PM   #7
hi davioh,
No point in guessing wat turn or wind the motor is.One way is to remove it out from the can and u will soon find out.
whether it a 23turn or 11 turn no point in guessing.
cheers....
monster_sg is offline   Reply With Quote
Old 04-10-2003, 11:29 PM   #8
davioh's Avatar
how do you tell once u remove it from the can??
Old 04-10-2003, 11:33 PM   #9
utieh's Avatar
it s not because the can is from Tamiya that ur motor is a 23T .
one can holf whatever a 9t or a 27t armature
a lot of small motor brand use other manufacturers can, armature and/or endbell to make their own .some just modify existing ones
you can (have to!) open any motor to pull out its armature, you can change it or just clean inside of the motor, before pulling it out, check the position of the enbell with the can (use a pen to mark its position) the endbell is setted up to have an angle (timming) that u can set with the can...my english become too bad
this text is from Balak racing, it is important to read it for understanding motor read the page too there are pics http://www.balakracing.com/commcutting.htm
Cutting Your Commutator
By Bryan Balak
For those of you that have been out of the hobby for a while, or maybe are new, electric motor care has become more and more complicated over the past few years. Some of us remember when everyone just ran that trusty 540 that came with the car. The thing was bulletproof. No diodes, capacitors, or serrated brushes. Just bolt that sucker on, and off you go. Nowadays, things are much more complicated. If you want to be competitive in the modified class, A comm lathe (or a buddy who has one) is a must have tool. Even the stock class has changed drastically since the debut of the first ROAR legal rebuildable stock motor. So why is it necessary to have the commutator cut on your electric motor every few races? Before we go any further, lets get some terms defined for those of us that may not know a lot about electronics and electric motors.
Armature – This is the part of the motor that actually moves. It is made up of the commutator, laminations, shaft and winds. When electrons are passed through the winds, an electric field is created that acts against the field the magnets in the can are generating. Since we have two forces pushing in opposite directions, movement is created.
Commutator – The part of the armature that comes in contact with the brushes. It is made of copper, and is usually divided up into 2-6 sections.
Laminations – The part of the armature the winds are wrapped around. These are usually about half a millimeter thick, and are stacked on top of each other. The laminations are sometimes shaped to provide a stronger field. They are usually made of iron ferrite.
Shaft – The part of the armature that rests on the bushings or bearings. I will refer to the shaft in two parts. The long end is the part of the shaft where the pinion gear is bolted on. The short end is the part of the shaft which the commutator is attached to.
Can – The outer part of the motor. It is usually made of steel or some other metal that can contribute to enhancing the magnetic field. The can contains the magnets. A lot of the newer cans, like the Trinity D4 will allow you to remove the magnets. The can holds the bearing that supports the long end of the shaft.
Bushing or Bearing – These are in the can and the hood of the motor. The shaft rests on these. Their sole purpose is to reduce friction. Bushings are made of copper and are found in ROAR legal stock motors and some budget modified motors. Bearings are always found in quality modified motors.
Magnets – These provide the opposing force that the armature’s magnetic force pushes against. If you don’t have magnets (or more specifically, an opposing magnetic field) then you don’t have an electric motor.
Shims – These are placed on both ends of the shaft. They reduce any unwanted space between the can/endbell and the ends of the armature. They are usually made of steel or Teflon.
Endbell – The part of the motor that consists of the brush hoods and the tabs. The endbell holds the bearing that supports the short end of the shaft.
Brush Hoods – These hold the brushes in place and keep them at a perpendicular angle with the commutator. The hood holds will sometimes contain hood springs that keep the brush from vibrating inside the brush hood.
Springs - These keep the brush in constant contact with the commutator. They are sold in different weights. You can change the motor's performance by adjusting spring tension.
Spring Post - These are what the springs are wrapped around.
Tabs - There are 2 tabs per side (positive and negative) on the motor. You can use both sets for soldering leads, diodes, capacitors, etc...
Timing Ring - This is used to advance the timing of the motor. In a stock motor, the timing ring is fixed, and cannot be moved. It is also what the endbell screws into to keep it attached to the can.
Shunt - This is the braided wire that comes out the end of the brush. Some shunts have eyelets on them so you can screw them onto the brush hoods. I prefer to solder them, as this gives maximum electron flow, and better efficiency.
utieh is offline   Reply With Quote
unknown chassis wait a minute Electric Off-Road 18 09-12-2006 09:16 PM
UNKNOWN MR-4TC CHASSIS...HELP? anthony390 Electric On-Road 7 01-15-2006 03:40 PM
?unknown truck? !!please help!! dato1000 Monster Trucks 7 03-27-2005 05:32 PM
Unknown Motor, and WIERD Brushes! Look! LosiFromHell986 Electric Off-Road 4 06-17-2004 01:13 PM
unknown ride davioh Electric On-Road 62 04-15-2003 02:50 AM
