Old 05-03-2007, 11:59 PM   #91
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Jason, get crackin' on that new 3.0mm pocketed MI3 carpet chassis now will ya!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-04-2007, 01:51 AM   #92
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Alex Lopez
As per Pw's request......
5 cell huh?
Old 05-04-2007, 07:30 AM   #93
dawgmeat's Avatar
Adrian
can you still use the green slime to lube the o-rings or with this process it's not needed
dawgmeat is offline   Reply With Quote
Old 05-04-2007, 07:36 AM   #94
AdrianM's Avatar
Originally Posted by dawgmeat
Adrian
On these shocks all you need is the silicon shock oil. I never liked the green slime. It was messy and contaminated the shock oil.
Adrian Martinez
Old 05-04-2007, 07:40 AM   #95
dawgmeat's Avatar
thanks
are you guys using foams or o-rings for shock rebound
Old 05-04-2007, 07:49 AM   #96
AdrianM's Avatar
thanks
Right now all our US setups are with no rebound, no orings or foam dots. However, we will be testing that in the future.
Adrian Martinez
Old 05-04-2007, 09:20 AM   #97
turbodog's Avatar
Adrian
I use the Schumacher diff lube, just a light coating on the o-ring and spacer. Also, be sure and lube the shock shaft before installing through the o-rings!
Troy Schafer
turbodog is offline   Reply With Quote
Old 05-04-2007, 10:17 AM   #98
Send a message via AIM to Alex Lopez
Originally Posted by Randy Caster
5 cell huh?
Car was really good for being box stock, and it will only get better. You run it yet?
Alex Lopez is offline   Reply With Quote
Old 05-04-2007, 10:52 AM   #99
No.. waiting on my package from KO and Much More, planning on hitting SoCal next Tues and Thurs, and hopefully outdoor that weekend.
Old 05-04-2007, 04:09 PM   #100
AdrianM's Avatar
Prepping the chassis is next. I run on road so I never have to get too crazy rounding edges. All I do is knock off every sharp edge on the chassis and CA the edges of the chassis and big openings. On asphalt we CA the chassis to prevent delamination if you hit a corner dot or some other object with the chassis.
The cell slots are the perfect size on the Mi3. DO NOT bevel the cell slots or you cell will poke out the bottom of the chassis. Just knock off all the sharp edges so the cell shrink is not cut.
Spend a little time on the tape slot to make sure the are smooth
The bulkheads go on to the chassis with 8 screws
Adrian Martinez
Old 05-04-2007, 04:17 PM   #101
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Dang...That box in the back ground makes me cross eyed and dizzy!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 05-04-2007, 04:19 PM   #102
AdrianM's Avatar
The lay shaft assembly is next. there are a few critical things to look out for.
1. Do not over tighten the screws that hold the spur gear on. Just get them snug. If you crank them down they will deform the spur gear and it will look like a potato ship...not good.
2. I use a counter sunk washer and screw to secure the end of the lay shaft. The stock button head and washer will work perfectly but my way looks cooler.
3. The layshaft assembly has a little side to side play. I used one 0.1mm shim out of a Take Off 5mm shim kit (TT302) to tighten it up a little. I still have play but it is a bit less. Note that you must have some play. If you shim out all the play its less efficient and if you pick up carpet fuzz or some dirt it can cause binding.
Adrian Martinez
Old 05-04-2007, 04:21 PM   #103
AdrianM's Avatar
EA
Must be a Paragon hangover from your last race...lol!
Adrian Martinez
Old 05-05-2007, 03:05 AM   #104
rc-car-net's Avatar
Send a message via ICQ to rc-car-net Send a message via MSN to rc-car-net
....The stock button head and washer will work perfectly but my way looks cooler.
[SIZE="1"][URL="http://www.Rc-Car-Net.at"][COLOR=RoyalBlue]Rc-Car-Net[/COLOR][/URL] [COLOR=Cyan]-=-[/COLOR] [URL=http://www.RC-FORUM.at][COLOR=RoyalBlue]RC-Forum.at[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.racing-cars.com][COLOR=RoyalBlue]Schumacher USA[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.fantomracing.com][COLOR=RoyalBlue]Fantom Racing[/COLOR][/URL]
:tire::sneaky:[/size][size="2"] ................................. :sneaky::tire:
:sneaky::tire:[URL=http://www.summerchamps.de][COLOR="DarkOrange"]GERMANY Summer Champs[/COLOR][/URL][/SIZE]:tire::sneaky:
:tire::sneaky: ................................. :sneaky::tire:
rc-car-net is offline   Reply With Quote
Old 05-05-2007, 11:33 AM   #105
RandyB's Avatar
Those bulkheads look hudge
RandyB is offline   Reply With Quote
WTT Schumacher Mi2's (with enough to build 2 cars) for your TRF415MSX jheimb4897 R/C Items: For Sale/Trade 18 02-24-2008 01:24 PM
TC5 build knox88 Electric On-Road 2 07-12-2007 10:45 AM
Build it yourself. TDyk Electric Off-Road 9 01-12-2007 10:18 PM
Build Your Own Car!!! blue hornet. Australian Racing 59 06-05-2005 06:04 AM
HPI R40 Build beowulf1877 Nitro On-Road 11 07-28-2004 09:44 PM
