Let's Build a Schumacher Mi3! >
Old 05-21-2007, 01:14 PM
  #211
AdrianM's Avatar
Originally Posted by protc3
before adrian leaves we should all demand a detailed explanation of cvd chatter and maybe throw in the molecular structure of a diff ball because i havent heard that one you da man adrian
I'm not telling you nothing...Mr. 4' Wide 1/12th car man
AdrianM is offline
Old 05-21-2007, 01:18 PM
  #212
The Evicerator
Man, you guys sure are cute together
Steve Weiss is offline
Old 05-21-2007, 02:05 PM
  #213
dbmartin's Avatar
Originally Posted by sf85
Thanks Jon - do you know where I can pick up some 600 grit sandpaper?
Aren't you supposed to be working??
And have you ever heard of Home Depot??
Rookie!!!!
dbmartin is offline
Old 05-21-2007, 02:32 PM
  #214
protc3's Avatar
quit driving like hellen keller then
protc3 is offline
Old 05-21-2007, 02:44 PM
  #215
adamge's Avatar
protc, I think you missed your calling in comedy.
adamge is offline
Old 05-21-2007, 02:49 PM
  #216
Regional Moderator
Darkseid's Avatar
You should be able to find it at any hardware store. Keep you eye out, some places sell individual sheets for only a couple cents, instead of making you buy a whole pack or multi-pack.
Darkseid is offline
Old 05-21-2007, 10:41 PM
  #217
Can someone please explain the building of stock servo saver? I can't for the life of me figure it out
The manual indicates that I should rotate the servo arm 180 degrees but I can't see how it would be possible to do it.
itchynads is offline
Old 05-22-2007, 03:42 AM
  #218
I also kill my head doing it, but my three weeks of experience on this car tells you not to loose to much time on it and dont use it. Chris Ashton also dont use it. I had some problems with the aligment of the steering, take it out and no problem now.
jorgesimes is offline
Old 05-22-2007, 05:42 AM
  #219
Skiddins's Avatar
Don't bother, it's crap.
The spring rubs on the servo when it's built
Skiddins
Skiddins is offline
Old 05-22-2007, 05:49 AM
  #220
Tech Legend
Marcos.J's Avatar
Trader Rating: 194 (100%+)
it was tricky but i got it together on the 3rd try ,yes it does rub the servo but it will do for now until i get another one
Marcos.J is offline
Old 05-22-2007, 07:48 AM
  #221
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
I'm brave. I went with the no servo saver setup.
wyd is offline
Old 05-22-2007, 07:49 AM
  #222
Tech Legend
Marcos.J's Avatar
i thought about it too , Adrian and PW dont use the servo saver either but they dont wreck like I do!!
Marcos.J is offline
Old 05-22-2007, 07:51 AM
  #223
wyd
Tech Legend
wyd's Avatar
Go for it. You have the Futaba 9550 in the car and it can take it. Plus you have a PW bumper.
wyd is offline
Old 05-22-2007, 07:55 AM
  #224
Tech Legend
Marcos.J's Avatar
i know im thinking about it ,the stock servo saver is so flimsy
Marcos.J is offline
Old 05-22-2007, 07:57 AM
  #225
wyd
Tech Legend
wyd's Avatar
Pier pressure will get the best of you. I feel like you will be changing it before you run your first pack thru the car.
wyd is offline
