Let's Build a Schumacher Mi3! >
Old 05-14-2007, 03:17 PM
  #181
its proprietary Martin
Originally Posted by dbmartin
adrian,
Are you ok w/ me taking your setup and build tips and transferring them into the fseara site?
sf85 is offline
Old 05-14-2007, 04:05 PM
  #182
dbmartin's Avatar
Originally Posted by AdrianM
I want to get it together and do some spelling and content corrections. Just wait a few days.
ok no problem, Thanks
gibson, if its the web, everyone steals, I mean shares info!!
dbmartin is offline
Old 05-14-2007, 04:24 PM
  #183
Did you read the post about the mi3? I bet your thinking real hard about getting one
sf85 is offline
Old 05-14-2007, 05:16 PM
  #184
dawgmeat's Avatar
Are you referring to me
dawgmeat is offline
Old 05-15-2007, 10:54 AM
  #185
dbmartin's Avatar
no
it was directed at sf85
dbmartin is offline
Old 05-19-2007, 03:49 AM
  #186
mattb's Avatar
great read so far is there any more build tips to come??
thanks mattb
mattb is offline
Old 05-19-2007, 03:54 AM
  #187
rc-car-net's Avatar
no - as far as i know there won't be any more tips to build a mi3.
adrian is now checking his grammer and then you can find the full article online!
rc-car-net is offline
Old 05-19-2007, 10:46 AM
  #188
Thanks to the Schumacher Team.... I am off to the track to pick up my new Mi3. They shipped it out Saturday delivery at 4:00 yesterday, THANKS GUYS!!
Anyways I have all of Adrian's tips in a word document if anyone wants just send me a PM and I'll email'em to you.
Thanks again for all the tips....
Ryan Flack
Ryan F is offline
Old 05-19-2007, 05:10 PM
  #189
Moderator
StephenSobottka's Avatar
Flack...I'll be at his n hers on Saturday hopefully with my MI3...lets get em dialed in!
StephenSobottka is offline
Old 05-19-2007, 05:33 PM
  #190
rc-car-net's Avatar
you don't have got the corrected version! right?
Old 05-20-2007, 06:05 PM
  #191
Default Adrian
There is a clip of Adrian's last interview he gave before leaving Schumacher. It is very insightful. I am sure Adrian will be missed but his voice lives on in this clip. Should be on the bottom right of the screen. It is seperate from the regular program. www.rctvlive.com Hopefully they will have the Mi3 on soon!
Ginsu is offline
Old 05-20-2007, 08:51 PM
  #192
On the lay shaft, the black piece that seperates the small belt from the large belt, is that supposed to move freely from side-to-side before the belts are attached?
Also, for the shocks, I noticed the o-rings that come with the kit look identical to the Tamiya o-rings, are they the same?
Thanks.
The lay shaft assembly is next. there are a few critical things to look out for.
1. Do not over tighten the screws that hold the spur gear on. Just get them snug. If you crank them down they will deform the spur gear and it will look like a potato ship...not good.
2. I use a counter sunk washer and screw to secure the end of the lay shaft. The stock button head and washer will work perfectly but my way looks cooler.
3. The layshaft assembly has a little side to side play. I used one 0.1mm shim out of a Take Off 5mm shim kit (TT302) to tighten it up a little. I still have play but it is a bit less. Note that you must have some play. If you shim out all the play its less efficient and if you pick up carpet fuzz or some dirt it can cause binding.
sf85 is offline
Old 05-20-2007, 09:27 PM
  #193
Mr. McGoo's Avatar
Thanks.
yes for the layshaft - it should be able to move from side to side.....
As for the orings - not really sure, but i know many shock orings out there are the same....
Mr. McGoo is offline
Old 05-20-2007, 09:40 PM
  #194
JayBee's Avatar
Trader Rating: 31 (100%+)
Nice link Ginsu
JayBee is offline
Old 05-20-2007, 09:49 PM
  #195
AdrianM's Avatar
Wow...I talk a lot
AdrianM is offline
