SPEED SIX OR JUST SIX >
Old 04-30-2007, 09:08 AM
  #16
Tsquare's Avatar
Originally Posted by AdrianM
The Mazda Speed 6 has more steering buy less stability. The Mazda 6 has pretty good steering but better stability.
This is exactly what I found between the two bodies, I ran standard wiings, no cut outs or air dampners, both wings mounted 1/4 inch past the rear bumper.
Tsquare is offline
Old 04-30-2007, 09:22 AM
  #17
Regional Moderator
Darkseid's Avatar
Originally Posted by Tsquare
I did cut out the slits in the Speed six wing. I used a blade to cut a hole, them used a small cutting wheel on my dremel to cut the rest and then used a small sanding wheel on my dremel to finish the job. It turned out to be more work then it was worth, I ran the car, with both wings, and preferred the wing without the slits, seemed more stable.
Interesting...
Darkseid is offline
