Old 04-27-2007, 07:44 PM   #1
16skyline's Avatar
Default DOES MOTOR TEMP CHANGE WITH SPUR SIZE
I am just wondering if you have the same final drive but change from small spur to big spur, will this change anything?
For example:
will you be slower through corners or faster?
will straight line speed change?
will your motor work less so will it run cooler or not
16skyline is offline   Reply With Quote
Old 04-27-2007, 07:52 PM   #2
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I would say no matter the ratio, with the taller spur the motor wont have to work as hard so therefore the temp would run cooler.
Good question.
That is pinion to spur ratio. If your running 10 to 1 it would run cooler than a 10 to 3. Tire diameter would make the roll out in gear?
I cant wait to hear responses on this question.
UN4RACING is offline   Reply With Quote
Old 04-27-2007, 08:02 PM   #3
Trader Rating: 28 (100%+)
For example:
The motor is still doing the same amount of work, if the final drive is the same it doesn't matter what combination you used to get there...
Ashley Cobb is offline   Reply With Quote
Old 04-27-2007, 08:16 PM   #4
Ya I think that the motor will run at the same temperature if the final ratio stays the same. Both the pinion and spur have to spin the same number of times for one full rotation. I am pretty sure that's the right answer but I could be wrong.
shaneriley2 is offline   Reply With Quote
Old 04-27-2007, 08:57 PM   #5
Suspended
CAlbrecht is offline   Reply With Quote
Old 04-27-2007, 09:18 PM   #6
UN4RACING's Avatar
Some how I thought it would be more complex then that.
Old 04-28-2007, 02:09 AM   #7
Drewdc90's Avatar
If you used bigger gears (spur and pinion) but still had the same ratio you would have slightly more rotating mass which would put slightly more load on the motor. I doubt it would affect the temp much, if it did it would be very minuet.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
If I change SPUR brands, will they fit my TC? Rufus2000 Electric On-Road 2 09-06-2008 07:44 AM
pinon and spur size 16skyline Electric On-Road 2 03-13-2007 10:23 PM
T2 Spur Gear Size butrflynlambie Electric On-Road 11 10-18-2006 05:25 AM
Engine Overheating - Change of wheel Size? Aceboy Electric Off-Road 6 06-05-2006 09:32 PM
How to change Tmaxx Spur gear boxersmurf R/C Tech Site Forum 1 10-17-2005 10:46 PM
