NEED HELP WITTH ROLLOUTS PLEASE
NEED HELP WITH ROLLOUTS PLEASE
HI GUYS,
I NEED SOME SUGGESTIONS FOR STOCK AND 19 TURN ROLLOUTS I RUN 62MM RUBBER TIRES.
I AM USING A P2K IN STOCK AT THE MOMENT I ALSO HAVE TWO MOTORS WHICH HAVE A CHROME CAN DON'T KNOW WHAT BRAND THEY ARE.
IN 19 TURN I AM RUNNING A INTEGY V 10R.
ALSO WHAT COLOUR SPRINGS SHOULD I RAN.
IN ADVANCE THANKS FOR LOOKING/ADVISE.
REGARDS
REGARDS
For rollouts...
www.gearchart.com is tops.
For which 19T on rubber tires that is a toss up. Komoto Dragon or Cheakpoint Money motor.
On the KD I like F brushes with either purple + red - or purple purple.
Hope that helps.
-Shookie <><
Hope that helps.
-Shookie <><
I USE GEARCHART BUT I WAS LOOKING FOR SUGGESTIONS OF WERE TO START WITH THE GEAR RATIO.
HELP PLEASE
Firstly turn off caps.
Secondly, if you can provide us with details of what you are doing, racing, drifting etc, then what size track you are going racing at, then we can help.
Without knowing these sorts of details no one can help you out that much as we would only be taking guesses.
As a general rule start stock about 27mm rollout and 19t about 24mm, depending on the track this can change significantly.
Sorry may i ask what is rollout? i am new and dun really understand wat it means.
http://www.stmcc.com.au/index1.htm
Here is some pictures of our track. Have a look it might help a little.
Thanks, but I don't know what the other guy's are doing still winning verry easy.
Ask one of the fast guys what their rollout is, if you bring us that figure we can help you out.
If you ask for help they should be more than willing to help you.
Also if they are faster than you on the straight while you are killing them in the corners you need to use a bigger pinion, if it is the other way around use a smaller one
That is the problem no one will help!!!!!
They are much quicker on the straights (about 8-10 car lengths) put I am not even cathing them through the corners.
I am running a team brood komondo in 19 turn 78 spur 23 pinion 48 pitch (final drive is 7.63, roll out of 25.53) in a trf415 with TA05 diffs.
In stock I am running a team brood (it is a black can motor not sure of make)
72 spur 26 pinon (final drive 6.23 roll out 31.26) again trf415 with tA05 diffs.
Both cars run 62mm rubbers on asphalt, does anyone have any suggestions?
rollout all depends too on your battery and motor setup. each little thing changes the characteristics of how your car handles, so... start with what one of the fast guys at your track is running, and adjust to your style.
what about the track owner? they usually can point you to someone who can help you...
hmmmm...
