Old 04-24-2007, 08:21 PM   #1
wikedgmc's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via MSN to wikedgmc
Default How to balance the Orion 4800
Anyone have any idea how I can balance these packs? There is a plug on the back side is this for balancing? What do I need to balance these cells?
thanks in advance
Powered by HobbyTown San Jose
wikedgmc is offline   Reply With Quote
Old 04-24-2007, 08:56 PM   #2
Default Balancer
Mike,
Check the attachment. It shows how to hook it up. I made one myself, should have shown it to you on Friday. E-mail me and I can send you pics of what I did.
Fernando
[RC10TC] is offline   Reply With Quote
Old 04-24-2007, 09:02 PM   #3
wikedgmc's Avatar
Will you be at Nor-Cal on Friday? I will send you my email in a PM
Old 04-24-2007, 09:06 PM   #4
Can't make it to any racing this weekend. Wife's B-day weekend. I'll try to attach a pic here.
The yellow wire goes to the balance plug in the battery. I just made one out of solder and used a dremel to shape it. Team orion makes a 2mm banana plug for it. I have one coming from tower this week. Team Orion part #62503.
How to balance the Orion 4800-balanceplug.jpg   How to balance the Orion 4800-balancer.jpg
Old 04-24-2007, 09:17 PM   #5
wikedgmc's Avatar
fair enough, I will see if I can get one made
Old 04-24-2007, 11:20 PM   #6
syndr0me's Avatar
Trader Rating: 32 (100%+)
Does the "2S" harness come with Orion's balancer? If not, where can one be acquired?
syndr0me is offline   Reply With Quote
Old 04-24-2007, 11:26 PM   #7
The Hyperion balancer comes with the 2S and 3S harness. I don't know if the Orion one comes with one.
Old 04-25-2007, 09:02 AM   #8
Rick Hohwart's Avatar
It comes with it.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 04-25-2007, 04:08 PM   #9
MrBlack's Avatar
The Orion SBS balancer comes with a 2S, 3S, 4S, 5S harnesses.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 04-25-2007, 04:11 PM   #10
Big B's Avatar
I heard it wasnt necessary to balance them
Big B is offline   Reply With Quote
Old 04-25-2007, 04:32 PM   #11
MrBlack's Avatar
It isn't, but people have been known to do some creative things with them on accident and can cause them to go out of balance if this happens balancing is a means to bring them back to their original luster.
Old 04-25-2007, 04:38 PM   #12
Big B's Avatar
Ok thanks
Old 04-25-2007, 05:09 PM   #13
wikedgmc's Avatar
I was reading on the Orion web site were it stated that they did not need to be balanced for the first 30 cycles, seeing as I have probably used them around 30 to 40 times in the past 9 months in my supervee and my brush less E-Maxx and wanting to use them in my 10th scale racer thought it would be good for them. They are probably pretty much balanced still as they will run for along time but cant hurt.
****** THESE ARE NOW FOR SALE ******
Old 04-25-2007, 11:46 PM   #14
myndesye's Avatar
There is nothing to it. The connection on the bottom of the battery is just a center tap. A point in between the two cells inside. Using a digital meter, connect to the tap and one of the standard battery leads. Do this to determine positive and negative connection points. For instance, if you put the positive lead from your meter on the tap, and the negative lead from your meter on the positive battery main lead, and the meter reads a negative value, then you should place the leads from your charger on in the reverse of that order. Once you have determined which end is positive and which should be negative, charge with your lithium charger on a 1 cell 4800mah setting, if it is not automatic. When finished, take your meter and do the same between the tap and the other main lead. Once both sides have fully charged, your pack will be balanced.
The search engine where they search for you
http://try.chacha.com/?rid=2536
myndesye is offline   Reply With Quote
Old 04-26-2007, 09:40 AM   #15
in every 2 months, I would charge my battery at 2S until it is close to 8.4. Once it's close to 8.4, I will switch to different charger and charge it at 1S for both + and -. So far so good, and I will have around 50 mAh gap taken out. It saves a lot of time too
azmio is offline   Reply With Quote
Orion 3.5, 2 Orion 4800 Lipos, RP36 tires! act2007 R/C Items: For Sale/Trade 21 08-30-2008 11:51 PM
Spektrum SR3000 RX, Orion 4800 Lipo, Orion 13.5 BL Jake S R/C Items: For Sale/Trade 40 07-06-2008 06:47 PM
Orion 4800 dodgeguy R/C Items: For Sale/Trade 3 03-10-2008 12:44 PM
tc5 with orion 4800 Need Help bigemike Electric On-Road 14 09-22-2007 12:34 PM
4800 LiPo Peak Racing, 2 packs like new (Orion 4800) ALJR R/C Items: For Sale/Trade 14 01-09-2007 09:37 PM
