Old 04-25-2007, 04:54 PM   #16
habis's Avatar
what about the orion element v2
habis is offline   Reply With Quote
Old 04-25-2007, 04:56 PM   #17
Suspended
They are the ones that blow up..
I heard the "new" motor is pretty close to a KD , but thats it..
CAlbrecht is offline   Reply With Quote
Old 04-25-2007, 05:57 PM   #18
RussB's Avatar
Send a message via MSN to RussB
Originally Posted by Elboogie
I wii try that because I still run with a 6.25 ratio after cutting the comm with infinity brushes. I wll try that because I still have a brand new checkpoint in my box. thanks for the info.
yeah, try around 5.6~5.7 then if you go as high as 6.25 with the atlas brushes. it's super torquey with the infinity brushes, and they stand up to the heat very well. it's probably gonna get a little hot, but if it doesn't smell burned and doesn't drop off in power then your not geared too high.
RussB is offline   Reply With Quote
Old 04-25-2007, 06:59 PM   #19
Kevin Boyle's Avatar
Checkpoint all the way
Larry,
How is the Losi
Later
Kevin Boyle
Kevin Boyle is offline   Reply With Quote
Old 04-25-2007, 07:04 PM   #20
16skyline's Avatar
When you are talking about your final drives, are you using 64 pitch or 48 pitch?
16skyline is offline   Reply With Quote
Old 04-25-2007, 07:07 PM   #21
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by MrBlack
Orion Vortex 10.5
Title says...19 turn...Not 10.5 turn...LOL
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 04-25-2007, 08:19 PM   #22
Big B's Avatar
Depends on the track, KD seem to be good on technical tracks like SIR, and I hear the Peak Dynasty is good on high speed tracks
Big B is offline   Reply With Quote
Old 04-26-2007, 08:04 AM   #23
habis's Avatar
strange comment about the orion element v2. the most commonly used 19t in my country i have never seen/heard any blow up.
Old 04-26-2007, 10:46 AM   #24
Big B's Avatar
I have yet to see a motor blow up, if you are blowing up motors and burning up brushes every run, it might not be a motor problem, maybe try changing the gearing
Old 04-26-2007, 12:51 PM   #25
sukh's Avatar
It should be the other way around, dynasty for short tech. Tracks (lots of grunt), and kd for fast flowing tracks (high rpm motor, hence why you gear your kd lower) and when I talk of motors going up in smoke itís the new dynasty not the old one, same thing for the orion element, I have seen at least 5 go up in smoke, not by new people to the hobby, there fast but donít last the 5 min.
sukh is offline   Reply With Quote
Old 04-26-2007, 12:59 PM   #26
Rick Hohwart's Avatar
We have found that the new Dynasty likes a gear similar to the Komodo or one tooth less. This is a big contrast to the old Dynasty which required a much larger pinion.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 04-26-2007, 01:35 PM   #27
Big B's Avatar
I know of one guy at SIR who tried the Dynasty, it dosent spin as freely as the KD so it dosent carry as much speed in the corner (on a technical track thats where you loose races), but that is just one guy, I havent tried it yet
Old 04-26-2007, 04:40 PM   #28
Trader Rating: 44 (100%+)
You can get the same result by reaching the same final drive ratio regardless of 48 or 64pitch.
My $0.02:-
1. The KDís are consistently fast. (Yet to see a slow KD!?!) But it requires more maintenance Ė comm. & brush wise.
2. The original Orion Element & Dynasty Ė fast & consistent once u get the gearing right. The V2 endbell is almost maintenance-free. Personally, I have not seen any Orion/Peak blowing up.
3. But my Atlas Red went up in smoke though. Although, it was running at around 70C~80C. It was a very fast motor. I felt it was overall faster than my Orion. Pity it's not a "ROAR-approved" motor ..
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 04-26-2007, 04:59 PM   #29
16skyline's Avatar
Does anyone know if there is a post with the most popular 19turn/stock motors listed with what they should be geared at.
This would be a great help to the average racer like my self.
If there isn't one could someone make a list up?
Regards
Old 04-26-2007, 05:05 PM   #30
Big B's Avatar
Regards
Depends on the track. I would suggest going to your local track, watch some of the Stock and 19T races, find out who's fast, and asking them what they run. 9 times outta 10 they will be more than happy to help you out.
Single Turn VS Double Turn purdyd82 Rookie Zone 16 08-01-2013 12:59 PM
Single turn and double turn motors Wreckless_Daz Electric On-Road 5 08-21-2007 02:35 PM
(WTA)3PKS PCM RX brand new market price in market now. sangyi41 Malaysian R/C Racers 0 03-20-2007 12:13 PM
Whats the fastest 19 turn and 27 turn stock motor? adr3naline fix Electric On-Road 104 08-26-2005 11:03 PM
Reedy Ti Standard Comm Armature, 10 turn & 8 turn brand new jason cheng R/C Items: For Sale/Trade 2 05-20-2004 01:17 PM
