Old 04-10-2003, 01:09 AM   #31
Cole Trickle's Avatar
Originally posted by fatdoggy
Cole Trickle - The diff measurements are in the attachment. Sorry it looks a little ghetto.
Thanks for the help.
P.s. I won't be getting the one-way for a few weeks so I don't need the sizes strait away.
Fine, I'll take a look at it. Probably in the weekend.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-10-2003, 01:11 AM   #32
I'll strongly reccomend, that you make your shocks a little longer. Then you can do all the adjustement with those fine droop-screws. Droop affect handling a lot.
Old 04-10-2003, 11:20 AM   #33
Alvin's Avatar
Guys,
Could you guys tell me more about the on/off power effects of a rear ball differential between loose to tight?
I'm running double one way, ball diff in the rear... rebuilt my diff a few days back and the car's setting went out of whack. Had to tune the tightness it all over to get the feel back again... thanks!
Alvin is offline   Reply With Quote
Old 04-24-2003, 03:35 PM   #34
Hello Fatdoggy, now it's here. I believe they are compatible. Hopefully you can read my "beatifull" hand writing
Old 04-24-2003, 03:56 PM   #35
fatdoggy's Avatar
R/C Tech Charter Subscriber
Yep I can read your hand writing just fine. Thanks for going to the trouble of measuring it for me. The measurments look pretty close so I'll give it a shot and see how it goes.
Thanks again.
fatdoggy is offline   Reply With Quote
Old 04-24-2003, 08:47 PM   #36
popsracer's Avatar
Originally posted by Alvin
Guys,
For ANY type of diff, Tighter settings, Thicker Oil generally translates to a looser Grip at that end of the Car.
Tighter Front diff, less Steering (push)
Tighter Rear diff, MORE steering, (Loose)
popsracer is offline   Reply With Quote
Old 04-25-2003, 09:24 AM   #37
TWiZTiD's Avatar
you can use the c 4.1 front one way in the c4 or the x ray one or even lock the front diff bye taken out the balls
this is how i ran my c4 up untill the start of this year
2mm toe out in the front 2 mm toe out rear
45 wt oill all round
white springs
2 mm drop
1 mm camber all round
fornt one way mid one way locked
middle hole on shocks
TWiZTiD is offline   Reply With Quote
Old 04-25-2003, 04:57 PM   #38
fatdoggy's Avatar
Thanks TWiZTiD
Camber Gain sachoppers Nitro Off-Road 1 06-25-2008 11:01 AM
on power steering!!! hyperrex8 Nitro Off-Road 3 11-27-2007 08:31 AM
777 sp2 too much on power steering Gen Nitro Off-Road 14 11-12-2007 11:20 AM
Power Capacitor to gain acceleration BigBear Electric On-Road 208 02-22-2007 02:25 AM
Any Performance Gain? Nrctc3 Electric Off-Road 8 08-01-2004 05:10 PM
