Old 04-22-2007, 04:46 AM   #1
Phroz's Avatar
Default XXX-S and Mamba brushless question
I just put a Mamba 7700 in my XXX-S. I'm using a 86t spur and a 19t pinion (48 pitch). Today i noticed after breaking that the spur and pinion seemed to be slipping and on closer inspection i noticed the spur has worn down (only about the 6th pack on this spur) I turned the breaking down to 65% on the ESC to try and stop it hapening again (had it on 80%) Also should these things get hot? I Have turned the timing down to lowest but the motor and batts (3500mah nimh) get pretty hot (the ESC seems to hum along nice and cool). I have checked the belt to make sure its not too tight and the car seems to roll pretty freey. Also (yes another also lol) would i benifit from changing to 64 pitch spur/pinion?
Cheers,
Ben.
Phroz is offline   Reply With Quote
Old 04-22-2007, 09:18 AM   #2
CRASH's Avatar
Trader Rating: 26 (100%+)
Cheers,
Ben.
Sounds like your gear mesh is to loose. Also your motor and batteries should get pretty warm, especially with the 7700.
Later,
CRASH is offline   Reply With Quote
Old 04-23-2007, 02:12 AM   #3
I)arkness's Avatar
i think your ratio is to high with 8.28 try gearing it down and then check the temps
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 04-23-2007, 03:35 AM   #4
Phroz's Avatar
so gearing is spur divided by pinion? ie 128t spur / 15t pinion = 8.53 ?
Old 04-23-2007, 04:03 AM   #5
I)arkness's Avatar
no
ratio =
its the spur/pinion x the internal ratio which is 1.83
86/19*1.83=8.28
B.Portelli
Old 04-23-2007, 04:09 AM   #6
Phroz's Avatar
ok just out of interest how do u work out that internal ratio?
Old 04-23-2007, 04:10 AM   #7
I)arkness's Avatar
each car has its own ratio it should be on the manual
but i think i has somthing to do with the diff sizes
B.Portelli
Old 04-23-2007, 04:26 AM   #8
Phroz's Avatar
great! just read that.. cheers! so givin this what FDR would u suggest i run for the 7700 ( i think its a 3.5turn to 4turn motor)
Old 04-23-2007, 09:56 PM   #9
I)arkness's Avatar
im not sure on that your better off posting that in the xxx-s forum as heaps of people would help you out
http://rctech.net/forum/showthread.p...47#post3238947
B.Portelli
Old 04-23-2007, 09:59 PM   #10
RussB's Avatar
Send a message via MSN to RussB
internal gear ratio is diff pulley / layshaft pulley. overal gear ratio is (spur / pinion) x internal ratio.
RussB is offline   Reply With Quote
Castle Creations MAMBA COMP X brushless system and 6800 brushless system for sale Ron Meloni R/C Items: For Sale/Trade 15 03-31-2008 04:32 PM
Mamba 25 question. mashaun Micro and Mini Scales 5 02-22-2008 01:53 AM
Mamba 25 question. mashaun Radio and Electronics 0 02-16-2008 09:06 AM
Brushless ammo motor and Mamba Max question. Revo21 Electric Off-Road 7 02-15-2008 08:45 PM
Mamba Max Question !!! blackdog Electric Off-Road 47 07-06-2007 06:42 AM
