Brushless systems >
Brushless systems
Brushless systems
Old 04-20-2007, 12:42 PM
Brushless systems
Hi Guys 1 quick question,
i just bought my novak brushless system the 3.5 one and need some help with it!
Now we race foam tyers in South Africa and with temps in the 30 degrees celcius!
Would like to find out where do i start my gearing what do i gear my 3.5 motor?
Many thank
heink is offline
Old 04-20-2007, 01:14 PM
SWTour's Avatar
not knowing what kind of car/truck etc. that's a hard question to answer...
I can tell you the 3.5 is rated at 10,500 rpm PER VOLT unloaded. If you run it with LIPO's it'll turn close to 90,000 rpm and probably close to 60,000 under load.
BIGGEST SPUR - SMALLEST PINION LOL
SWTour is offline
Old 04-20-2007, 01:16 PM
RocketRacer's Avatar
Hello Hein, my fellow South African.
i also currently run the 3.5 Novak system. you want to have the car geared in the 11~11.25 zone. this gearing is based around rubber tyres where the diameter would usually be in the region of 64mm. so with foams you can calculate you rollout and gearing as you wear down. you should also monitor the temps on your motor and don't want it to ever get hotter that 79degrees celsius. the syste has a thermal shutdown feature, but you should also monitor the temps with a temp gun. you will definitely be flying with the 3.5R. i watched you drive at the last Nationals. you were on fire!!! so i take it you will be running the brushless at K90 Nats?
hope this helps
Paul
RocketRacer is offline
Old 04-20-2007, 01:33 PM
SWTour
Sorry forgot to mention i`am driving the Xray T2`oo7 With tyer diam of about 59mm i cut a set for each run so the tyer sizes will stay the same right throug the nats!
heink is offline
Old 04-20-2007, 01:40 PM
Hey Paul
havent yet desided on what iam running at the nats Brush or Brushless, i went to practice at k90 a couple of times this year already and managed to do 24 laps in most of my races and 24 laps is the pace to beat! Now i nw the brush system works at k90 and after the race i have about 200 secs left in my batt, which i think is gr8!
but the guys that runs brushless like Micheal and Wimpie are just as good through the infield (not that k90 has mush of a infield) my car is gr8 and make meters on them but down the straight the pass me like im looking for parking! Now i reckon if i get the brushless sorted out i will be as quick as them on the straight and even quicker through the infield!
But like i said i need to start playing with the brushless system just 2 c where i am!
Are u racing this nationals at K90?
heink is offline
Old 04-20-2007, 01:48 PM
i won't be running the K90 Nats.
what are the other guys running, brushed or brushless. i am sure that with the brushless you will have the speed on the straight. but yes, i suppose you do need to find the sweet spot for the gearing with the brushless for the K90 track.
what brushed setup are you running?
Old 04-20-2007, 01:54 PM
Welll the wimpie is running the mamba system and micheal the lrp system!
Currently i am running nosram speedo with a oscar jansen V motor!
heink is offline
Old 04-20-2007, 02:03 PM
then you must run your brushless!! you have to defend your keywest win!
