Old 04-07-2003, 12:57 PM   #1
Cole Trickle's Avatar
Default Tires/inserts versus weight
Usually, I use molded inserts, but I would like to try out some sponge-types. But I've read that they can have heat-problems at the end of a race.
The temperatures on the tracks I race on, vary from 0 degree celsius to 25 (32-77 deg. F)
During races, I only run for 5 minutes per. session with 30-60 minute pauses inbetween. During practise, I run for around 8 minutes per session, and often only with 10 minutes pauses.
Are sponge inserts proper for these conditions?
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-07-2003, 05:30 PM   #2
JohnA's Avatar
In my experience foam inserts can help in very low grip conditions, but don't provide enough support for the tyre when the grip is OK. This leads to fast and un-even tyre wear.
I don't think any weight advantage will be that noticeable.
JohnA is offline   Reply With Quote
Old 04-08-2003, 03:30 AM   #3
Sounds reasonably. Thanks.
Old 04-08-2003, 08:04 AM   #4
popsracer's Avatar
Generally what you will see with a too soft insert is excessive wear on the inside edge of the Tire (grooving). A large air gap can cause this too.
Unless the Traction is very poor (even with the best tires), I would stick with Molded inserts.
popsracer is offline   Reply With Quote
NIP HPI tires, inserts and wheels gatrbite R/C Items: For Sale/Trade 4 12-12-2004 06:04 AM
Tires And Inserts Ko Racer R/C Items: For Sale/Trade 0 11-20-2003 02:16 PM
Reduced rotating mass versus weight transfer Cole Trickle Electric On-Road 4 08-08-2003 11:47 PM
Tires versus grip Cole Trickle Electric On-Road 7 07-13-2003 11:47 AM
Tires Inserts Question Ralf Electric On-Road 9 06-08-2003 01:32 PM
