What are the best cells? >
Old 08-10-2007, 07:48 PM
  #91
Wink
Originally Posted by jordys jrxs View Post
hi all, im gettin kenw cells aswell.. just wodnering how many time do you think a pack shud be used in a day.
i do 6 races at a club meeting so how many 6cell packs will i need?
jordan
For a racing pack, how many cycles per day, seriously to say, cycles effect packs' life, but as our experience in lab, 6cycles per day no problem.
We even tested our packs cycle life in lab, 30 cycles per day, the capacity is downing. after 200 cycles, the capacity lose 10-15%. but volt has a little higher.
Like that......
epower4500 is offline
Old 08-11-2007, 06:14 AM
  #92
hi all, thanx for the very very quick reply.
i have orion 3700's atm, but they are not performing as they should they are about a year old and the only get 2800mah in them.
i have a protrak charger/dishcarger... is there any way i canbring them back to how they should perform. or at least make them better.
jordan
jordys jrxs is offline
Old 08-12-2007, 08:29 AM
  #93
you 'd better charge them by 0.2C , then -10mV, discharg them by 0.2C , like this for 3 cycels, then charge them still by 0.2C, discharge them 5C, the next step is 0.2C charge, 10C discharge.
Now, I guess the pack 's capacity will back a little. pls try..... this method will help you......
Old 08-13-2007, 01:53 PM
  #94
ok, thanx for the advice ill give it a try.
jordan
Old 08-14-2007, 07:04 AM
  #95
part-time racer's Avatar
Trying to race some 5 cell mod at the moment and i can't get my cells to last 5min. I'm using brand new Green Power 4500. charging @ 5amp.
If I can't get the cells to work, what will?
part-time racer is offline
Old 08-14-2007, 11:00 AM
  #96
How to discharge them? 30A ? or higher?
Actually, there are two kinds of Sub-C cells, I means, same capacity, but same volt.
For example, there are two packs, both 4500mAh, but one Avg volt is 1.23V, but the other is 1.1V.
Of course you can run the first pack continously, but the other can not, if you discharging them by big current, the pack's volt will be low too quick, even can not going on supply power. but after resting 5mins, your pack will back the volt, it can going on work, but several mins after, the problem will back...... only like that.
For this kinds of pack, only can use in little kids ' toys.
Old 08-14-2007, 11:07 AM
  #97
razzor's Avatar
Bud might not be your batteries but the gearing on teh car.
Try going down a tooth or two on the pinion.
What class are you running ???
With a 4500mah pack you should have ample run time unless you running borderline in mod.
razzor is offline
Old 08-14-2007, 11:23 AM
  #98
I'm running an LRP B/L @ a big out door track. the gearing is anywhere from 7.1 < 7.65 fdr.
I know the fdr is in the right place.
My discharge rate is 30Amp.
Going to try some LRP V-Tec 4200 big mama's. I've heard good things.
Old 08-16-2007, 07:32 PM
  #99
it is batteries' problem!!!
Old 08-17-2007, 02:46 AM
  #100
Ordered 3 sets of SMC IB4200 WC . Hopeful that will take care of the power issues!
Old 08-17-2007, 02:48 AM
  #101
Thumbs down
I'll be advising people not to waste there money on these Green Power 4500. Unless there using them in Mini Mardave's.
