Much-More CTX-D2 >
Much-More CTX-D2
Much-More CTX-D2
Old 04-18-2007, 07:07 AM
forum fodder's Avatar
Default Much-More CTX-D2
Does anyone know how long the CTX-D2 takes to discharge a 4200mah pack on the 30A pulse discharge? In other words what is the equivalent linear discharge rate to the 30A pulse discharge?
forum fodder is offline
Old 04-18-2007, 07:20 AM
Fully charged about 45 to 50 minutes.
SRW141 is offline
Old 04-18-2007, 09:08 AM
So pretty much the same as the 5A linear then.
Old 04-18-2007, 09:11 AM
I've never discharged a complete pack at 5A linear. I only equalize with linear.
SRW141 is offline
Old 04-18-2007, 07:09 PM
Big B's Avatar
I just did a couple of new 6 cell 4200's at 30amp pulse and it took between 50min to 1 hr 15min I havent yet done it a 5amp linear
Big B is offline
Old 04-18-2007, 09:06 PM
VooDooPH's Avatar
Trader Rating: 18 (100%+)
read it somewhere... the 30A pulse discharge is effectively a 5A linear dischare... pulse 1 sec at 30A then 2 sec rest...
VooDooPH is offline
Old 04-21-2007, 05:00 AM
When I charge a battery pack and then discharge it using the pulse discharge, I get a different IR reading than when I discharge it after a 5 minute race. Is this normal? If so, what reading is the true one?
kobiwan is offline
Old 04-21-2007, 05:07 AM
GymBeam's Avatar
IR will never be the same. usually the first use of the day the IR will be higher than the second use.
GymBeam is offline
Old 04-23-2007, 10:38 AM
R/C Tech Elite Member
JayL's Avatar
also, much more has said the IR is only accurate on a full discharge, not a partial after race one...how can it know what IR you had during the race?
JayL is offline
