Like Tree2Likes
Tamiya TA05MS
Old 07-06-2010, 09:58 AM
  #1381
Andysan's Avatar
Anyone know of any parts that are hard to get for this car please? I run a TA05R and parts are very easy to come by, but the MS uses special belts of which there doesnt seem to be much availability.
Cheers!
Andysan is offline
Old 07-06-2010, 10:12 AM
  #1382
Skitee's Avatar
The belts for the 05-MS are special order items, if you're in a bind for a front belt the front belt from the Tamiya DB-01 buggy is the same length it's just a little wider but does the job.
Skitee is offline
Old 07-06-2010, 10:29 AM
  #1383
Andysan's Avatar
Ah, dang it. I am considering buying an MS but can only find one seller selling the belts, and no-one seems to make aramid belts either (unless the stock ones are?). This is probably enough to put me off buying what looks like a great car!
Thanks for your help!
Andysan is offline
Old 11-11-2010, 01:58 AM
  #1384
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Is there a comprehensive list of Tamiya belt lengths anywhere?
I'd like to swap in the 18T centre pulley to lower the IDR, in order to get better gearing for untimed 21.5 brushless. However, the standard belts are just that tiny bit too short and become too tight.
Alternatively, does anyone know which belt will fit well in this configuration?
phil.
PDR is offline
Old 11-11-2010, 02:22 AM
  #1385
Skitee's Avatar
Here's a thread that has most of the current belt sizes liosted.
http://www.rctech.net/forum/electric...us-cars-3.html
Skitee is offline
Old 11-11-2010, 03:39 AM
  #1386
PDR
PDR's Avatar
That looks great - thanks!
PDR is offline
Old 11-11-2010, 08:07 AM
  #1387
Allex2000's Avatar
Hi friends!!
There are a gear diff for TA-05?? I'm searching for this but I dont find it...any diff of the other car can be used in TA05?
Awaiting, thanks!!
Allex2000 is offline
Old 12-12-2010, 11:56 PM
  #1388
OverGeared's Avatar
Trader Rating: 17 (100%+)
What about the rear belt?
OverGeared is offline
Old 04-14-2011, 11:40 AM
  #1389
nicorozog's Avatar
Eyy guys.. do you know where i can get spare and hop up parts... for this car? TA05MS....?? Thanks a lot...sorry for the rookie question!
nicorozog is offline
Old 04-14-2011, 11:45 AM
  #1390
What are yo looking for? You can use arms, knuckles, hubs, chubs from most any new car. Belts ar harder to find. I found some on ebay.
DOTMAN is offline
Old 04-14-2011, 03:50 PM
  #1391
nicorozog's Avatar
I bought a TA05 MS, and i want to use it with a 10.5 motor, in parking lot, asphalt. However, everything can happens, so if i brake some parts...where can i get de part to replace? also i think that i can use parts of TRF 415... Oo not?. And i want to know what hop ups??
Thanks a lot!
Old 04-15-2011, 03:22 AM
  #1392
Just check the manual for the part numbers. I still have mine and even though I raced it solidly for 2 years with a 10.5 I only ever had to replaced a front knuckle. The only part that wore down was the aluminium drive cups (TA05 aluminium diff parts). The belts etc are still as good as new.
As for hop ups there isn't many, I replaced the suspension shafts with coated ones and the suspension pistons also with the coated ones. Other things are more cosmetic such as the carbon bumper mount.
It's a high spec car out of the box, just drive it and enjoy it
Qatmix is offline
Old 04-15-2011, 08:24 AM
  #1393
Thanks a lot!
you don't need any hopups with this car. It's got everything you need. The parts that break can be replaced with parts from a 415, 416, and even the 417. The only difference is the suspension blocks. The MS can't use the split blocks. I liked this car because it handled great and it is also easy to put a lipo in it. You'll enjoy it
DOTMAN is offline
Old 04-15-2011, 11:38 AM
  #1394
nicorozog's Avatar
Dotman thanks a lot bro. I've been reading the thread and ofcourse understanding the behaviour of the car. Hope to see more good comments here...
Old 04-29-2011, 03:34 PM
  #1395
nicorozog's Avatar
Eyy guys.... i´ve read all the thread and i see that some people use Lipo with this car, but i want to know... which is the best lipo that fix on the car.
And if is necessary use Lipo Tray..where can i get it!..
Thanks a lot!
