Like Tree2Likes
Tamiya TA05MS
Old 05-12-2009, 07:20 PM
  #1321
...have gotten myself a TA05 MS thanks to a mate. Now its time to dial it in!
exotica is offline
Old 05-16-2009, 07:55 AM
  #1322
cool, let us know what type of circuit / motor / tyres you are running. Its a great car especially when you get it all hooked up. Mine has been consistantly getting me in the A final. Superb car
Qatmix is offline
Old 05-17-2009, 01:48 AM
  #1323
...Sorex wheels and 27 rated tyres added. Running Yeah Racing 5.5T 6000kv motor and 60A ESC, together with a 5000mh Yeah Racing Lipo! Just insane fun.
FDR is 9.4 and will really have some fun for a few speed runs when I adjust the FDR to around 5 or 6.
exotica is offline
Old 05-25-2009, 01:39 AM
  #1324
Fast XXXS's Avatar
Trader Rating: 50 (100%+)
Ok guys i am wanting to stiffen my car up, its pretty much stock atm with a few changes. Where and what would be the best place to start? I cant really go changing oils etc as i dont have a varity of tuning items. Im wanting my car to transition left to right quicker. Any help would be great.
Fast XXXS is offline
Old 05-25-2009, 03:47 AM
  #1325
Cribbin's Avatar
yep i found that the car lacking in fast direction changes with the stock set up.
you can do a few things....
1) stiffer springs
2) stiffer roll bars
3) remove the spacer between the hubs and the front wheels
4) raise the front roll centre. specifically, i have a 1.5mm spacer under the inside of the front camber link.
i have done all of this and the car is a rocket. option 3 made the best (not biggest) improvement.
cheers
ben
Cribbin is offline
Old 05-25-2009, 04:07 AM
  #1326
Fast XXXS's Avatar
1) stiffer springs
cheers
ben
Sweet thanks mate ill give them a go. Is that stiffer springs all round? also when you say remove the spacers between the hubs is that the clamp spacer or the little blue shim/ spacer?
Old 05-25-2009, 04:12 AM
  #1327
HI_808's Avatar
What's your set up now?
I remember that you asked about setting your car up for a spool. Back then, I erroneously said that a car with a spool likes more Ackerman. What I meant was spooled cars turn better with more spacers in the steering assembly which actually equates to less Ackerman.
HI_808 is offline
Old 05-25-2009, 04:24 AM
  #1328
HI_808's Avatar
Oh, I've been keeping up with Jilles' thread and his tips helped me to get my TA05MS and 416 really dialed. My old setups worked, but they were always flawed in some way or another.
I highly recommend using a spool, short LW arms, suspension mounts to go with the short arms, and zero degree rear uprights. I've attached my TA05MS set up with these items.
HI_808 is offline
Old 05-25-2009, 05:39 AM
  #1329
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Just curious, do you use the short arms? I found that without at least a 0.5mm wheel spacer, the tyres tended to rub.
PDR is offline
Old 05-25-2009, 06:00 AM
  #1330
Skitee's Avatar
Rubber on 0 degree offset rims were fine, foams on 0 degree offset rims were too close and would occasionally rub.
Skitee is offline
Old 05-25-2009, 04:36 PM
  #1331
Cribbin's Avatar
no i dont use short arms, and yes the wheels will rub sometimes but u can fix it easy. Just use a sharp blade and shave the steering knuckle a little bit. The ball cup also needs doing a bit... If u do this the wheels wont rub at all.
If you look around at different rims they actually have slightly different offset, even though they say 0 or 2 or whatever. I always run 0. Also softer rims flex more, so they may rub when u hit something, which, of course, i would never do
FASTXXXS yes that is stiffer all round. I always run as stiff as i possibly can, because it makes the car more nimble and more responsive. It also makes it sit flatter through the corners, equating to more corner speed. And you will find that the more upright your rear shocks, the better it will do this. Remember that the only thing grip does is slow a car down, but we need it yo get round the corner.
Ben
Cribbin is offline
Old 05-25-2009, 08:48 PM
  #1332
Fast XXXS's Avatar
HI_808- My setup is pretty much stock except i have a spool, front shocks are mounted fully out on the towers, rears are in the middle. droop is about 3 all round springs are stock yellow.
Cribbin- Yes i am lacking corner speed which i found is crucial for 17.5. I have some harder springs that ill put in for some testing.
Old 05-25-2009, 09:10 PM
  #1333
Cribbin's Avatar
omg if your front shocks are all the way out then of course it wont turn fast enough!! lean them in to the 2nd or 3rd hole and it will be heaps better. and your droop - is that actual droop or the downstop setting? i find it best when the downstops are 5mm front 4mm rear.
what is the track you are running on like? How is the surface?
Cribbin is offline
Old 05-25-2009, 11:19 PM
  #1334
Fast XXXS's Avatar
Ok ill give it a go on the weekend. Um im not sure what the down stop is but i use an associated droop guage and adjust the long grub screws in the suspension arms. The track im running on is low to med grip ashphalt, pretty tight with alot of hair pins, lap times are around 16.5sec for 17.5.
Old 05-26-2009, 12:40 AM
  #1335
Cribbin's Avatar
yeah downstop setting is measured with the droop gauge, same thing.
give it a go and let us know how it goes, we will work from there...
Cribbin is offline
