Like Tree2Likes
Tamiya TA05MS
Old 08-16-2008, 10:50 PM
  #1081
Trader Rating: 23 (100%+)
Originally Posted by sandrixx View Post
Don't think so it'll fit. My good friend bought a pair like that and he said it doesnt fit the MS.
well do you know of one that will. i found another on ebay that i could buy too. i hope someone knows if this one will work.
http://cgi.ebay.com/ws/eBayISAPI.dll...ksid=p3907.m29
not home is offline
Old 08-17-2008, 12:34 AM
  #1082
HI_808's Avatar
The Square knuckle will work. The second 3Racing knuckle that you were looking at appears to be for the TA05 with the original suspension. You would be able to use the TA05IFS/TB03/TRF416 knuckle if you switch over to the new style suspension.
HI_808 is offline
Old 08-17-2008, 07:34 AM
  #1083
ravenwolf's Avatar
Default question
Hi,, Just want to ask your opinion.., is the TA05MS chassis capable for Brushless/Low turn(motor) racing?..
ravenwolf is offline
Old 08-17-2008, 08:29 AM
  #1084
some people dont think its for the mod class but the 10.5 13.5 stock and stuff.
not home is offline
Old 08-17-2008, 08:32 AM
  #1085
if the square one will work then i will buy it today. thanks.
not home is offline
Old 08-17-2008, 08:49 AM
  #1086
subaru73's Avatar
Trader Rating: 42 (100%+)
Default o5 ms
Stick with 13.5 or 10.5 and you will be fine that is what I race my car with.
subaru73 is offline
Old 08-17-2008, 06:02 PM
  #1087
ravenwolf's Avatar
Default 05MS for 3.5 BL/7T motors
has anyone or anybody tried this kit on mod racing?.. any feedback regarding handling and parts wear...? thank you
Old 08-17-2008, 07:18 PM
  #1088
the reason im wanting the aluminum steering knuckles is because of the stock ones wear. the under side of it, the screw once you take it out and strew it back in, it will fall out with one tap on a wall it seems. the threads in the part are so weak that i need aluminum.
not home is offline
Old 08-17-2008, 09:32 PM
  #1089
waOscar's Avatar
make sure you got Aluminium diff outdrives. Finding a spool if required for the front is not easy. everything else is fine.
waOscar is offline
Old 08-18-2008, 12:12 AM
  #1090
ravenwolf's Avatar
Default thank yu
Already got the front spool aswell as the Alum diff outdrives. My concern is the design of the chassis,,that is a midmotor mount.,, compared to the 415 or the 416. I'm concerned about the would be handling if i used any 3.5BL motor. any modifications to make it handle the speed and power of mod?
Old 08-18-2008, 09:33 AM
  #1091
does anybody know where i can get or what type of screw is needed to screw into the blue aluminum wheel hex? i broke mine halfway inside it and got it out but i would like to get hold of a screw that fits inside there.
not home is offline
Old 08-18-2008, 04:30 PM
  #1092
kavadni's Avatar
Tamiya 9805893 is a 10 pack $2.25 from RCMARKET.com.hk
Kevin
kavadni is offline
Old 08-18-2008, 06:20 PM
  #1093
Kevin
can you show me the link, cant find it.
not home is offline
Old 08-19-2008, 04:53 PM
  #1094
kavadni's Avatar
http://rcmarket.com.hk/product_info....roducts_id=523
The worst thing about that site is that the search is broken.
Kevin
kavadni is offline
Old 08-19-2008, 08:50 PM
  #1095
guys i am thinking of either getting a trf416 or TA05ms....which one shd i choose?....
JeremyT is offline
