Like Tree2Likes
Tamiya TA05MS
Old 06-21-2008, 01:12 AM
  #1036
Top stuff!
thanks for that.
Also would my ta05 front diff fit in the ms if I wanted to take out the front one way?
Qatmix is offline
Old 06-21-2008, 03:04 AM
  #1037
kavadni's Avatar
Originally Posted by Qatmix View Post
Top stuff!
thanks for that.
Yes, but I suggest you buy another aluminium diff.
I run 2 diffs, no oneway. Race primarilly on small carpet track [basketball court size]
Cheers
Kevin
kavadni is offline
Old 06-21-2008, 05:03 AM
  #1038
thanks,
What parts do I need to buy to make an aluminium diff?
Qatmix is offline
Old 06-21-2008, 10:02 AM
  #1039
kavadni's Avatar
thanks,
1 x 49425 [Blue] or 1 x 53919[Silver] Diff Joint
1 x 50880 Diff Plates
1 x 53379 Balls
1 x 9949300 Thrust Bearing
1 x 9949299 Diff Spring
1 x 9949350 Diff Screw
1 x 53935 Pulley
You'll also need 2 x 850 bearings
Cheers
Kevin
kavadni is offline
Old 06-21-2008, 11:33 AM
  #1040
fantastic! Cheers for that
Qatmix is offline
Old 06-21-2008, 05:00 PM
  #1041
nikkiesteban's Avatar
anyone succeeded installing 18t pulley in 05ms?
in tried it but the belts are too short for 18t.
nikkiesteban is offline
Old 06-21-2008, 05:07 PM
  #1042
E-clip's Avatar
Trader Rating: 39 (100%+)
hi
If you change the pulleys to 35t black pulleys from the TRF415 then the 18t centre will fit. This reduces the internal ratio to 1.944
This is what i have done to my car
E-clip is offline
Old 06-21-2008, 05:15 PM
  #1043
Originally Posted by E-clip View Post
hi
i see..
So which is much better in terms of IDR?
the 35t black pulleys paired with 18t pulley?
or the 36 pulley with 16t pulley?
you are clever.. I didn't think of it putting 35t pulley. hehe
Old 06-21-2008, 05:25 PM
  #1044
E-clip's Avatar
The stock racing in australia has now moved to the 17.5bl so the final rollout of the car is about 60mm to get the 17.5 going so, with the high internal of 2.25 this it near impossible to do
With the internal ratio of 1.944 this rollout is done by using a 65spur with a 38t pinion
lowering the IR also achieves better accelaration
That's my 2 cents
E-clip is offline
Old 06-21-2008, 05:39 PM
  #1045
That's my 2 cents
i see. well thanks for that.
I will use silvercan on my 05ms.
I will try the 35t and 18t pulley combination and see how it will work.
Old 06-22-2008, 11:34 AM
  #1046
Can anyone tell me the part numbers for the aluminium servo mount and the carbon front bumper brace?
Cheers
Qatmix is offline
Old 06-24-2008, 10:32 AM
  #1047
Hi,
Can someone let me know if you need the trf415 stabilizer sets for this car? Mt ta05 ones dont seem to fit.
Cheers
Qatmix is offline
Old 06-24-2008, 04:57 PM
  #1048
kavadni's Avatar
Hi,
Cheers
The TA05 ones. They are the same size as the 2 rods that came with ms.
I used the TA05 servo mounts, I have been told, but haven't tried. You can use the 415 servo mounts.
Kevin
kavadni is offline
Old 06-24-2008, 05:25 PM
  #1049
Fast XXXS's Avatar
Trader Rating: 50 (100%+)
Just a quick question.
What size tool will i need to fit the majority of the screws on my MS?
Fast XXXS is offline
Old 06-24-2008, 07:48 PM
  #1050
94eg!'s Avatar
Trader Rating: 17 (100%+)
2mm is the main size. The smaller ones like grub-screws and cap-screws are 1.5mm...
94eg! is offline
