Like Tree2Likes
Tamiya TA05MS
Old 04-13-2008, 11:19 PM
  #961
Centerfire's Avatar
Trader Rating: 6 (88%+)
e-clip : Hi mate, ASPHALT? OR CARPET? mod or stock?
Centerfire is offline
Old 04-14-2008, 02:21 AM
  #962
Martinst's Avatar
Well I've been running the TA05ms now for 3 rounds of our local indoor carpet racing and its been quite impressive out of the box. Easily competitive and the handling has been quite neutral. The main issue I'm having is back end grip, or lack of it. On power its fine but once the powers lifted the back end just slides around on the bends. I've tried reducing the rear end droop incase the weight transfer was picking up the back end, but still no real inprovements. I don't want to lose any of the steering as the tracks are quite twisty but this sliding is really killing my lap times.
Martinst is offline
Old 04-14-2008, 02:52 AM
  #963
VooDooPH's Avatar
Trader Rating: 18 (100%+)
tried lowering the rear roll center? or laying the rear shocks down a hole or 2?
VooDooPH is offline
Old 04-14-2008, 03:21 AM
  #964
TryHard's Avatar
Hey Martin,
I would go with trying moving the front shocks out on the tower to start, and also try running more shims on the front axle.
If you really want to try something different, try D/D on the front suspension blocks. This will widen the front end, and make the front arms parrallel, which should help massively with reducing your lift off oversteer.
HiH
Ed
TryHard is offline
Old 04-14-2008, 04:24 AM
  #965
Martinst's Avatar
Originally Posted by TryHard
Hey Martin,
HiH
Ed
cheers Guys,
I'll try a few options out. Just need the car to be less twitchy through the bends, hopefully one of the suggested fixes will work. Its crazy, but even at club level one spin can cost you the race.
Martinst is offline
Old 04-14-2008, 05:52 AM
  #966
@sd
Hi guys!
Does this fit the TA05MS?
RC Front Direct Coupling - TA05
Item #53877
Is there anything else needed to change from the kit front 1 way to a front spool?
Thanks!
@sd is offline
Old 04-14-2008, 09:39 AM
  #967
kavadni's Avatar
Originally Posted by @sd
Hi guys!
Item #53877
Thanks!
That is the correct part, and that's all you need
Kevin
kavadni is offline
Old 04-14-2008, 09:45 AM
  #968
kavadni's Avatar
You can also try:
Stiffer front springs - stop the nose from going down.
Stiffer front stabilizer - increases rear traction.
Stand front shocks up - similar to the already suggested lay rear down.
And as already mentioned and as you have tried less rear droop.
Kevin
kavadni is offline
Old 04-14-2008, 03:36 PM
  #969
HI_808's Avatar
You can also mess with the front roll center or add anti-dive.
HI_808 is offline
Old 04-14-2008, 07:49 PM
  #970
Just purchased an MS and have a trakpower 4900 lipo. J/w how much lead weight to add and where to balance it best?
dennyboy424 is offline
Old 04-15-2008, 12:23 AM
  #971
@sd
hey guys a quick one
Does the following comes with plastic/delrin outdrives or steel/aluminium outdrives?
Item #53877
Thanks!
@sd is offline
Old 04-15-2008, 04:01 AM
  #972
I know this is overkill, but what pinion size should I start with for a 9 turn double?
Interceptor is offline
Old 04-15-2008, 03:10 PM
  #973
I glue 200 grams of weight to the roof top of my Mazda 6...that seems to work best...yep...dialed
DOTMAN is offline
Old 04-16-2008, 05:22 AM
  #974
Martinst's Avatar
Does anyone know where this goes on the TA05ms, is it an upgrade ? worth having etc ????
Martinst is offline
Old 04-16-2008, 06:45 AM
  #975
AaronR's Avatar
Trader Rating: 113 (100%+)
I hate to post this in here, but if anyone is interested in a clean, low usage 05MS, let me know. I have chosen to sell mine due to other interests this summer and my budget won't allow me to keep it. Great car, lots of usable spare parts, etc.
AaronR is offline
