Old 03-06-2008, 03:53 AM   #946
Martinst's Avatar
Can anyone recommend a pinion and spur gear combo for a 27T setup ? In door carpet, main straight max 30 metres.
Martinst is offline   Reply With Quote
Old 03-06-2008, 07:41 AM   #947
TryHard's Avatar
Hi Martin,
Start off with a 27t pinion. Should give your a final drive ratio of 8.75 (with standard 105t spur). That'll be close enough to start with.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-06-2008, 05:53 PM   #948
guinnes.s's Avatar
Originally Posted by guinnes.s View Post
after fitting a spool and about 10 minutes racing i noticed that the wheels hex's on both the front wheels have been rounded.
can it be the plastic on the wheels that is not good or something wrong with the ally hex in the car???
if i use the front diff is ok,only when using the front spool the problem appears.
thanx
Salvo
sorry to bump up this post but wondering if anyone have the same problem and how to solve it.
thanx
guinnes.s is offline   Reply With Quote
Old 03-06-2008, 10:53 PM   #949
HI_808's Avatar
What type of wheel hub are you running and how many spacers, if any, are you using?
HI_808 is offline   Reply With Quote
Old 03-07-2008, 02:17 AM   #950
guinnes.s's Avatar
the wheel hubs are the stock 5mm and without spacers
Old 04-12-2008, 04:10 AM   #951
@sd
Default Servo Mount
Hi there!
Does any one here know which aluminium servo mount to be used for TA05MS?
Item #53723 RC TB Evo IV Alum Servo Mount - Blue
or
Item #53875 RC Aluminum Servo Stay - TA05 Lightweight
Thanks.
@sd is offline   Reply With Quote
Old 04-12-2008, 08:26 AM   #952
Centerfire's Avatar
Trader Rating: 6 (88%+)
Originally Posted by @sd View Post
Hi there!
or
Thanks.
Actually you can use it Both! the only difference is the design and the weight!
Centerfire is offline   Reply With Quote
Old 04-12-2008, 09:57 AM   #953
diesel's Avatar
Hi there, may I know the height clearance between the main chassis and the top deck for the 05ms? Can it take a 28mm thick lipo pack?
Thanks.
diesel is offline   Reply With Quote
Old 04-12-2008, 05:04 PM   #954
zenithrr's Avatar
yes and no, though.
the upper deck has 26-27mm clearance. stick the lipo out a little bit, you should be able to clear the upper deck.
TA05MS, F201, F103GT, RS4 Mini, TopForce (original), Mini Inferno, **Tamiya BMT 931 K4** "I am a new soul, welcome to the new world, so proud to joint the TEAM MORON. lalalala" We love Onions products, so touching. COL - cry out loud
zenithrr is offline   Reply With Quote
Old 04-12-2008, 11:57 PM   #955
@sd
So which one do you recommend?
Old 04-13-2008, 08:13 AM   #956
E-clip's Avatar
Trader Rating: 39 (100%+)
Default Spacers
Hi
Could some please tell me what the part no# for the spacers that go under the toe blocks ??
Thanks mike
E-clip is offline   Reply With Quote
Old 04-13-2008, 08:56 AM   #957
bobbyvegas's Avatar
Originally Posted by Martinst View Post
Well I'm getting there, just waiting for the radio handset and receiver to come through the post and I can run the car. Got a Novak GTX and trinity monster to start me off.
Interesting to see how it compares to my TT-01, which is pretty well hopped up with diffs, one way etc. ( MRT Pro speedo is current away for service / repair )
MS
And my TT-01 ( 100 grams heavier than TA05ms )
Nice looking rides
2011 iic Poker Champion
bobbyvegas is offline   Reply With Quote
Old 04-13-2008, 09:25 AM   #958
Originally Posted by E-clip View Post
Hi
Thanks mike
Did you mean these?
http://www.racingfactory.fi/shop/cat...2_0611_9fe.jpg
Part# 53932 for 0.5mm spacers
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 04-13-2008, 03:31 PM   #959
E-clip's Avatar
Yes there the ones thanks
Old 04-13-2008, 11:24 PM   #960
Centerfire's Avatar
use the lightweight!
Tamiya Ta05ms subaru73 R/C Items: For Sale/Trade 12 10-02-2008 07:25 PM
Tamiya TA05MS Italian racer R/C Items: For Sale/Trade 15 03-24-2008 09:53 PM
FS: Tamiya TA05MS Hebiki R/C Items: For Sale/Trade 3 02-01-2008 06:30 PM
FS: TAMIYA TA05MS ONE RUN! Chris Furman R/C Items: For Sale/Trade 13 10-20-2007 05:16 AM
TAMIYA TA05MS m3ndo5a R/C Items: For Sale/Trade 4 08-14-2007 11:24 AM
