Like Tree2Likes
Tamiya TA05MS
Old 01-31-2008, 03:40 AM
  #901
Another little tip, lube the threads on the turnbuckle for easier install and screw in the cup only a few turns on both sides to get the threads started. Then install them in the car and adjust them to correct lenght with the turnbuckle tool. This saves your fingers from hurting.
Mr_Orange is offline
Old 01-31-2008, 02:18 PM
  #902
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by subaru73
welcome,there is no problem with anti wear grese for the diff i have used it before or you can use any good quality diff lube.
did you get my PM?
Hebiki is offline
Old 01-31-2008, 08:59 PM
  #903
Stein Tumert's Avatar
Tamiya also has a nice little tool to install the ball cups on the turnbuckles...
It holds the ballcup for you so no hurting fingers...
Stein Tumert is offline
Old 02-01-2008, 02:31 AM
  #904
peejay's Avatar
Do you have a part number for this?
peejay is offline
Old 02-01-2008, 09:15 AM
  #905
94eg!'s Avatar
Trader Rating: 17 (100%+)
94eg! is offline
Old 02-02-2008, 04:27 AM
  #906
kavadni's Avatar
Default Spring Question
Does anybody familiar with Ed Clark's Universal Spring Chart, know the part number for the Tamiya Silver Springs.
Kevin
kavadni is offline
Old 02-02-2008, 04:19 PM
  #907
TryHard's Avatar
Kevin
Not sure you can get them seperate, as they tend to be included with kits, such as the TT01 etc.
HiH
Ed
TryHard is online now
Old 02-02-2008, 06:16 PM
  #908
kavadni's Avatar
Thanks Ed,
I had wondered that. It means I already have them . I'jj
Can you and others outline how the TA05MS compares to the 415 and 416 cars. I am curious as to if the 415/416 offer tuning options over the TA05MS.
Kevin
kavadni is offline
Old 02-02-2008, 09:25 PM
  #909
Another Q guys
are there any hop ups available for this car?
i guess that motor cooler plate is one?
kevinicus is offline
Old 02-02-2008, 11:16 PM
  #910
HI_808's Avatar
Thanks Ed,
Kevin
I think the main difference between the 415MSXX and the 05MS is the weight distribution. Both are highly adjustable. I don't know anyone with a 416, nor have I owned one, so I can't comment on that.
I used to have a 415MS and I find the 05MS weight distribution to be better for our small course. My friend just got a hold of a 415MSXX MRE, but he hasn't got it dialed for that track. Hopefully once it's running well, we'll see the difference between the latest 415 and the 05MS.
Originally Posted by kevinicus
Another Q guys
Are you talking about the blue heat sink for the motor? If so, yes, you can use that on the 05MS. There are a lot of options available for this car: aluminum servo mounts, spool, diff balls, flourine coated ball nuts, center one-way (I think you can use the regular TA05 center one-way), Ti suspension shafts, hard coated dampers, Ti/Al screws, etc. The trick to getting parts for this is car is figuring out which ones come from the Evo IV, Evo V, TA05, or the TRF415.
HI_808 is offline
Old 02-02-2008, 11:54 PM
  #911
kavadni's Avatar
Another Q guys
There is an aluminium airduct 3454480
CF Bumper Support 4304089
and various other parts from evos and 415 as mentioned.
I am not sure if the TA05 center one way works, as the shaft is of different design. Tamiya released a center one way for the TA05 porsche 934 - 53952.
We have that on order and will be able to compare to the standard 05 center oneway soon.
Kevin
kavadni is offline
Old 02-06-2008, 04:35 AM
  #912
guys ive finished building!
heres a quick shot ...
Also,, what kinda servo should i be looking at?
any advice in directions guys?
to suit a 4.5 Novak
Old 02-06-2008, 09:25 AM
  #913
Trader Rating: 32 (100%+)
How'd you manage to fit Tyco wheels/tires on it?
ittjv is offline
Old 02-08-2008, 04:34 PM
  #914
guinnes.s's Avatar
hi guys,anyone with a good set-up for carpet racing with a 19t and LRP27 tires?
and yes can you suggest a good servo that will not break the bankplease.
always wondered what is for!!!!( inside the red circle )
guinnes.s is offline
Old 02-08-2008, 04:45 PM
  #915
guinnes.s's Avatar
