Like Tree2Likes
Tamiya TA05MS
Old 01-14-2008, 11:36 AM
  #871
g12314's Avatar
Aaron,
Check out this site:
http://www.thard.co.uk/excel.html
Jimmy
g12314 is offline
Old 01-14-2008, 11:53 AM
  #872
RC MARKET's Avatar
Originally Posted by guinnes.s
what size are the diff balls?and witch one would be better then the stock one?
thanx again
Salvo
3mm size
www.rcmarket.com.hk
RC MARKET is offline
Old 01-14-2008, 01:26 PM
  #873
Originally Posted by CarKing
As anyone had issues with the initial steering on this car? For some reason I have not been able to get the initial turn in even as good as my TA05. I need to get some new tires, but regardless, it doesn't seem to want to rotate on the initial corner entry.
My MS is the best car I have right now. It turns in hard. What your setup?
DOTMAN is offline
Old 01-14-2008, 02:00 PM
  #874
AaronR's Avatar
Trader Rating: 113 (100%+)
Originally Posted by g12314
Aaron,
Jimmy
Looks good, thanks!
AaronR is offline
Old 01-20-2008, 06:58 PM
  #875
kavadni's Avatar
Originally Posted by AaronR
Got electronics into my 05MS yesterday! Very fun, ran about 4 packs thru it (old IB3800s w/ Novak 17.5) on carpet. Look forward to get more wheel time with the car.
What is the correct Tamiya spring kit to use with the car? My springs are all white with a dab of yellow paint on all 4. Where can I find a Tamiya spring chart for touring cars? Thanks for the help anyone.
Aaron,
The springs that come with MS are the yellow springs from Tamiya 53440 - On Road Hard Tuned Spring Set. (See Parts Listing at back of your MS manual).
I have just received my MS and this is the set that I have been using on my existing TRF Dampers fitted to my TT-01. Most people who race with me also use that set.
Cheers
Kevin
kavadni is offline
Old 01-20-2008, 07:44 PM
  #876
kavadni's Avatar
Default Stabilizer Holder - Servo Mounts
Can Anybody confirm that:
1. Tam 53916 TA05 Alu stabilizer holder fits the MS
2. Tam 53723 TB Evo IV Alu Servo Mounts fit the MS
Regards
Kevin
kavadni is offline
Old 01-20-2008, 08:51 PM
  #877
fire929's Avatar
Default Hello Guys
Little help here! The Ta05ms can compete in GT1 for the TCS? and has anyone raced with a 415 and how idi the car stand up????
fire929 is offline
Old 01-21-2008, 02:03 AM
  #878
HI_808's Avatar
I read reports that said in the last TCS Worlds, Rheinhard and other TCS drivers used the TA05MS and beat out a lot of guys using 415s. But maybe most surprisingly, a Japanese kid with a plastic tub TA05 was even faster!
HI_808 is offline
Old 01-21-2008, 04:36 AM
  #879
habis's Avatar
this just shows thatīs not only equiptment - but also talent
habis is offline
Old 01-23-2008, 01:45 AM
  #880
kavadni's Avatar
Default Lightweight Screw Question
Could someone who is lucky and has the Champ Titanium and Aluminium Screw Set please tell me where they use the Aluminium vs where they use the Titanium.
Kevin
kavadni is offline
Old 01-23-2008, 10:58 AM
  #881
hemi426's Avatar
Kevin
All the Screws through the chassis plate are titanium, the rest is aluminium.
hemi426 is offline
Old 01-23-2008, 05:32 PM
  #882
kavadni's Avatar
Default Titanium & Aluminium
Thankyou, Glad I asked.
I was only going to do the suspension blocks, and the steering.
Kevin
kavadni is offline
Old 01-23-2008, 10:35 PM
  #883
kavadni's Avatar
Default Servo Mounts
Can anybody who has a standard TA05 tell me if the servo mounts are the same dimensions as those on the MS. I am wanting to replace the few plastic parts on the MS. Yes! This is my first aluminium and CF car.
Kevin
kavadni is offline
Old 01-24-2008, 09:38 AM
  #884
hemi426's Avatar
Kevin
No, they're not the same. You can use the mounts of the Evo IV.
hemi426 is offline
Old 01-24-2008, 09:45 AM
  #885
kavadni's Avatar
Thanks very much, I shall add them to my HK order.
kavadni is offline
