Like Tree2Likes
Tamiya TA05MS
Old 12-31-2007, 05:30 AM
  #856
nikkiesteban's Avatar
Originally Posted by Centerfire
Hi nikki,
Yes! and im really enjoying, sooo fast! how are you? haven't seen you at big races here in manila?
yes i cant join races "busy studying".......
maybe some other time i can attend some events.
happy new year!
let's enjoy our 05ms ahehe
nikkiesteban is offline
Old 01-02-2008, 11:29 AM
  #857
AaronR's Avatar
Trader Rating: 113 (100%+)
I can't decide what car to get (TA05-R vs MS)! First touring car, will be running 6-cell, rubber tire, Novak 13.5SS and LRP Sphere Comp 07 ESC. I think fitting the LRP ESC behind the motor on the TA05-R might be a tight squeeze due to the tub chassis. MS comes with a front one-way also which I will need for indoor carpet racing anyway with low power motor (again 13.5). TRF416 is a little much to start out with also, even though it would only be ~$75 USD more.
AaronR is offline
Old 01-02-2008, 05:56 PM
  #858
bighurt98's Avatar
Default PM
Check your PM.
bighurt98 is offline
Old 01-06-2008, 09:09 PM
  #859
CLK@racing's Avatar
Purchased the relevant parts to get the 416 steering fitted into my 05MS.
All seem to fit snugly together. Just need to flip the steering around.
Attached are two poorly taken photos.
As expected, the problem is securing the top center mount to the top deck.
Just fitted it last night, have not really try it yet. Do not know how it will affect the handling though.
But one thing's for sure, at least you cleared the steering from hitting the belt.
Attached Thumbnails Tamiya TA05MS-06012008283-small.jpg   Tamiya TA05MS-06012008282-small.jpg
CLK@racing is offline
Old 01-07-2008, 02:44 AM
  #860
HI_808's Avatar
Nice! I wonder how the altered chassis flex characteristics are going to influence handling along with the new steering set up. Let us know how it works out.
HI_808 is offline
Old 01-07-2008, 09:35 PM
  #861
guinnes.s's Avatar
hi guys ,just got a ta05 ms,and want to fit a front diff.
do i need to order every single part separately for build it ,or there is a diff set ready with all the parts? what size are the diff balls?
thanx
Salvo
guinnes.s is offline
Old 01-08-2008, 02:31 AM
  #862
HI_808's Avatar
You have to buy the parts individually.
HI_808 is offline
Old 01-08-2008, 03:04 AM
  #863
guinnes.s's Avatar
what size are the diff balls?and witch one would be better then the stock one?
thanx again
Salvo
Old 01-08-2008, 04:51 AM
  #864
g12314's Avatar
Aaron,
Either will be great. I have a TA05R w\ the 13.5 GTB setup in it, and the fit was no problem. I've been running mine down at The Track and have had no problem keeping up with the competition (yes, my 415 is a tick faster, but cost twice as much). However, I did buy the CF shocktowers, a oneway (havent used it yet), and some other additional hopups, so the cost goes up a bit. If you get the TA05R, drop a line, and I can share the setup we have been using to start w\ on Carpet.
I've been watching for a used Ta05MS to try out on the carpet to see how it compares.... Anyone wanna sell one CHEAP?
Another thing is, if you plan to race the TCS race at trackside, what class do you want to fall into GT2 (tub chassis 13.5) or GT1 (any chassis 10.5).
Jimmy
g12314 is offline
Old 01-08-2008, 07:16 AM
  #865
AaronR's Avatar
Originally Posted by g12314
Aaron,
Jimmy
Jimmy thanks for the reply, you have PM.
AaronR is offline
Old 01-08-2008, 06:57 PM
  #866
subaru73's Avatar
Trader Rating: 42 (100%+)
Default front diff
you have to buy all of the parts to build a complete diff,or you can use a ta05 spool.the diff balls are 3mm i personally use acer racing diff balls with no problems.
subaru73 is offline
Old 01-11-2008, 02:10 AM
  #867
guinnes.s's Avatar
hi guys,would a trf415msx front spool fit the 05ms???
thank you.
Salvo
Old 01-11-2008, 05:34 PM
  #868
subaru73's Avatar
Default 415 spool
i believe that it will not work,ther are plenty of places you can get the correct ta05 front spool.
subaru73 is offline
Old 01-14-2008, 10:23 AM
  #869
AWK
AWK's Avatar
As anyone had issues with the initial steering on this car? For some reason I have not been able to get the initial turn in even as good as my TA05. I need to get some new tires, but regardless, it doesn't seem to want to rotate on the initial corner entry.
AWK is offline
Old 01-14-2008, 10:47 AM
  #870
AaronR's Avatar
Got electronics into my 05MS yesterday! Very fun, ran about 4 packs thru it (old IB3800s w/ Novak 17.5) on carpet. Look forward to get more wheel time with the car.
What is the correct Tamiya spring kit to use with the car? My springs are all white with a dab of yellow paint on all 4. Where can I find a Tamiya spring chart for touring cars? Thanks for the help anyone.
AaronR is offline
