Like Tree2Likes
Tamiya TA05MS
Old 11-25-2007, 06:16 PM
  #826
rickchannon's Avatar
looking for setup outdoor asphalt w/10.5 BL medium traction takeoff 27 tires
rickchannon is offline
Old 11-26-2007, 03:18 PM
  #827
habis's Avatar
Originally Posted by Cruisaaja
Hey there
Ok, it`s time to go to Sweden today. I have been running lately Novak 8.5 and Lets see what happen when i try to my MS first time betweed mod racers out there
See you later guys...
so, how did it go????
habis is offline
Old 11-28-2007, 11:28 AM
  #828
Not so good
After when i put Vector 4.5 in it, weekend termination saldo was 2 spurgear, 2 wheels, front belt and M6 body including bad driving... f-final
But trip was very relaxing..
Cruisaaja is offline
Old 12-18-2007, 08:08 AM
  #829
MonkeyNuts's Avatar
Hi All,
I have decided to buy a TA05MS instead of the 416 because i've been running the tub one now for nearly 2 years and it is great. How easy are they to setup? i will be running indoors on medium traction carpet. This has probably been asked and answered (cant be bothered to back through all the posts), but does it use the same belts as the tub chassis version as they look different in the pics of it?
Cheers
Liam
MonkeyNuts is offline
Old 12-18-2007, 11:03 AM
  #830
Originally Posted by MonkeyNuts
Hi All,
Cheers
Liam
This car really is a TA05 in name only. With the exception of the diffs, it's about as close to a TA05 as the 415. The belts ARE different lengths. The car is awesome though. I love mine (I even bought a second one). It's easy to setup and drive. I push mine really hard and it responds well. What I like is that it's a very dependable car. Consistency is what wins races and this car drives the same lap after lap. I've raced it in 13.5 stock only but my times have been very close to 10.5 times. There have been times where I've actually had a better overall time with my MS running stock then I did in 19T running my 10.5 car. I can't compare it with the 416 since I don't have one but I can say for sure, you won't be unhappy with the MS. My car is fast now and I really have only just started playing with setup changes. The car seems to just get faster each outing.
DOTMAN is offline
Old 12-18-2007, 01:00 PM
  #831
MonkeyNuts's Avatar
Looks as though i made the right choice. Could anyone give me the parts numbers for the front and rear belts as i can't find them where i have been looking.
Cheers,
Liam
Old 12-18-2007, 01:19 PM
  #832
6244014 Tamiya TA05 MS long belt
6244015 Tamiya TA05 MS short belt
I ordered mine from rcchamp
DOTMAN is offline
Old 12-18-2007, 03:48 PM
  #833
HI_808's Avatar
I don't think the 415/416 setup is ideal for 10.5 or 13.5 because there is too much rear wheel traction. I think Tamiya designed the TA05MS to be their fastest car in those classes.
HI_808 is offline
Old 12-18-2007, 03:59 PM
  #834
I don't know about the 416 but my 415 was dialed in stock too
DOTMAN is offline
Old 12-18-2007, 05:03 PM
  #835
HI_808's Avatar
I couldn't get my 415MS to handle well with a 27 turn on my small course. Always had problems with the lack of steering. My TA05MS was easy in comparison to set up on the same course.
HI_808 is offline
Old 12-18-2007, 05:29 PM
  #836
Ah...I see
DOTMAN is offline
Old 12-18-2007, 08:06 PM
  #837
E-clip's Avatar
Trader Rating: 39 (100%+)
Default Suspension mounts
Hi all
Can anyone tell me what the different suspension mounts are ???
The mounts that go under the bulk heads, and like other kits have degrees the tamiya ones have letters A,B,C,D ???
What degrees are each letter ????
E-clip is offline
Old 12-18-2007, 08:57 PM
  #838
HI_808's Avatar
See TryHard's website:
http://www.thard.co.uk/excel.html
There is ~.5 degrees difference between each letter. The widest is 1E and the narrowest is 1XD. For example, the stock TA05MS setup uses 1B for the rear rear mount and 1XD for the rear front mount giving ~3 degrees of toe in at the hingepin.
The TRF415 mounts are designated with a "1" before the letter (for example, "1A", "1B") and are 1 mm lower than the Evo mounts with just the letter (for example "A", "B").
HI_808 is offline
Old 12-18-2007, 11:12 PM
  #839
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
Should be 1XB for rear front and 1D for rear rear.
-KilleR- is offline
Old 12-18-2007, 11:50 PM
  #840
HI_808's Avatar
Oops! Thanks for the correction !
HI_808 is offline
