Like Tree2Likes
Tamiya TA05MS
Old 10-04-2007, 05:36 PM
  #691
Xanavi_R34's Avatar
[QUOTE=rampal;3732290]for a big wide high speed track with a 3.5r, I'm with the spool... I'm using one right now and it's like night and day... and you still have brakes ... perhaps for the 23t the one-way will give you better feeling, however I don't know what you can do with a 23t on big track.... I just get deeply bored on the straight.... hehe.
Hahaha... Hey, thanks for the reply about spool and one way... The track that I am running is not like yours, yours is very BIG... In where I run is only maybe more than a half in the straight...
Anyway, thanks again!
Xanavi_R34 is offline
Old 10-04-2007, 06:49 PM
  #692
HI_808's Avatar
Originally Posted by nikkiesteban View Post
i see. well im waiting for my item..
is this steel?
and where i should put the shims?
The black outdrives are steel. You can use the shims between the bearing and the lip on the outdrive. I don't really find them necessary on the TA05MS as there as not as much play between the lip and the bearing in comparison to the TA05.
I think one-ways truly shine when paired with motors in the "stock" power range on smaller courses. The rear-wheel drive corner entry feeling is great; no other configuration gives that kind of corner entry speed and line. But even in that range of power, if you are on a larger track where you need to slow down very quickly, say for instance, if coming off a straight, then the lack of brakes can be a serious disadvantage.
HI_808 is offline
Old 10-04-2007, 06:54 PM
  #693
nikkiesteban's Avatar
i see. is there a piece of outdrives that i can get.. like delrin outdrives so i can replace the steel?
nikkiesteban is offline
Old 10-04-2007, 07:03 PM
  #694
HI_808's Avatar
According to ittjv and rampal, you need:
TAM9804268 - 415 MRE Replacement outdrives
TAM9804267 - 415 MRE Aluminum Spool Drive Cup
I am probably going to start using the delrin outdrives as well.
HI_808 is offline
Old 10-04-2007, 08:34 PM
  #695
Xanavi_R34's Avatar
What's wrong with the steel???
Old 10-04-2007, 08:40 PM
  #696
i got my spool..
ang the steel outdrives are heavy..
maybe if the outdrives and dogbones are steel..
the dogbones or universal shafts may bend when we crash.
correct me guys if im wrong.
and by putting outdrives instead of steel.
which of them will break if crashed?
Old 10-04-2007, 11:23 PM
  #697
Tomie's Avatar
Trader Rating: 38 (100%+)
Mine seems to hold very good (considering my car likes to fly 3ft from the ground sometimes )
Tomie is offline
Old 10-05-2007, 12:42 AM
  #698
Drifting101's Avatar
Default Help!!!
Does any one know if the ms carbon fibre lower deck will work with the stock ta05 parts? Please see image
Drifting101 is offline
Old 10-05-2007, 01:54 AM
  #699
rampal's Avatar
dont think so... this is for the 05MS which has different motor mount, belts and upperdeck... if you want to transform your TA05 on carbon, I reccomend you to search for a kawada, penguim or a kawahara carbon fiber chassis kit (around US$100-120)... otherwise just buy the 05MS kit (around USS 340).
cheers,
al
rampal is offline
Old 10-05-2007, 01:59 AM
  #700
buboy28's Avatar
am pretty sure that the stock TA-05 bulkheads and motor mount wo'nt fit with the MS lower deck do'nt know about the suspension parts though
buboy28 is offline
Old 10-05-2007, 03:08 AM
  #701
Xanavi_R34's Avatar
i got my spool..
Nice... Haha... Please tell us how it will perform with a spool... Comparison... Etc etc...
Old 10-05-2007, 04:38 AM
  #702
im building my spool now. and the shaft that is holding the outdrives are falling..
did you put a glue or thread lock in it? so it will not fall. need reply ASAP. tahnks
Old 10-05-2007, 04:39 AM
  #703
rampal's Avatar
the shaft is kept in its place by the bearings... you should be ok.... at least on the delrin ones it doesn't move....
al
rampal is offline
Old 10-05-2007, 04:49 AM
  #704
al
ohhhh.. thanks... hehe.. i will continue building.. thanks al.
Old 10-05-2007, 07:29 AM
  #705
done.. I noticed it chatters much when turned left and right?
