Like Tree2Likes
Tamiya TA05MS
Old 10-02-2007, 02:48 PM
  #661
Trader Rating: 118 (100%+)
Originally Posted by Hebiki View Post
thats 4.94.. that seems a little too much for a 10.5. you might be able to get away with that on a 13.5 on a larger track. not sure about a 10.5 though?
I was running that on the medium/small track with the 13.5 and it was doing pretty good.. motor got pretty warm, but never OMG hot.
Possibly a more torquey setup for the 10.5 like 96/38 - 5.68FDR?
I don't think the 105t for a brushless motor is necessary, brushless motors are already pretty high in torque.
Chris Furman is offline
Old 10-02-2007, 03:41 PM
  #662
Hebiki's Avatar
Trader Rating: 26 (100%+)
oh i get it now. i thought you ran 4.94 on your 10.5 at the same track.
im usually around 4.4-4.8 for my 13.5 and 5.1-5.4 with my 10.5. it all depends on the track size.
Hebiki is offline
Old 10-02-2007, 06:54 PM
  #663
HI_808's Avatar
True, brushless motors have loads of torque, so a smaller spur helps to run the lower FDRs. But you can find a little extra rear wheel grip with a larger spur since it helps to bias a tad more weight rearward.
HI_808 is offline
Old 10-02-2007, 08:18 PM
  #664
Double Quattro's Avatar
Anyone have the part# for the Air Scoop that mounts to the bottom deck?
I just ordered the top and bottom decks along with the belts. I'm going to convert my 934 50th kit into an MS! They are identical cars except the MS has a longer wheel base.
Has anyone tried running the short arms on the MS? How was the performance and do the 46mm shafts work?
Thanks for any info!
Double Quattro is offline
Old 10-02-2007, 10:31 PM
  #665
rays_tt's Avatar
I got my air scoop from rcmarket click
rays_tt is offline
Old 10-03-2007, 03:20 AM
  #666
what the heck is an air scoop and what does it do?
Old 10-03-2007, 03:28 AM
  #667
habis's Avatar
The TA05MS, MSX MRE, and MSXX has a triangle hole in the chassis where on top you mount the Air Scoop/Duct. This will channel air from under the car to the motor for cooling...........
habis is offline
Old 10-03-2007, 05:25 AM
  #668
rampal's Avatar
increase the bling factor!!!
rampal is offline
Old 10-03-2007, 07:21 AM
  #669
bmmer701's Avatar
Trader Rating: 17 (100%+)
does it really have an effect? like what's the temp of the motor if you use one of those. thanks
bmmer701 is offline
Old 10-03-2007, 08:42 AM
  #670
rampal's Avatar
I haven´t seen any clear indication that it works... at least on brushless... and I'm running a 3.5r so you can imagine the speed of it... nevertheless, it helps me to quickly change the esc on the car, just taking one screw!!!
rampal is offline
Old 10-03-2007, 10:01 AM
  #671
AWK
AWK's Avatar
Bling, weight, and really changes nothing. I have run my car with and without it and can see no difference in temps on the motor. But do I run it.....of course.
AWK is offline
Old 10-03-2007, 11:09 AM
  #672
Hebiki's Avatar
you need to run yours at BCR alongside me, jose and oliver!
Hebiki is offline
Old 10-03-2007, 11:27 AM
  #673
AWK
AWK's Avatar
I am going to pick up a LRP and Novak 13.5 in the next few weeks along with some RP30s and a Mazdaspeed6 and then i will make the trip out there. My 19t is dying for a rebuild, and I would rather be all in than nothing!!!!
I am definately looking forward to it though as Dave keeps bugging me about it at work too!!!!
AWK is offline
Old 10-03-2007, 11:42 AM
  #674
Hebiki's Avatar
dave coming out to BCR again this sat?
Hebiki is offline
Old 10-03-2007, 11:56 AM
  #675
AWK
AWK's Avatar
Don't know off hand, but I will ask him. It wouldn't surprise me unless he has gotten sick of beating up on people with his TA05
AWK is offline
