Like Tree2Likes
Tamiya TA05MS
Old 09-22-2007, 01:43 PM
  #646
Tomie's Avatar
Trader Rating: 38 (100%+)
Just wondering.. does the 3200/4800 Orion Lipo fit the TA05MS chassis?
Thanks!!
Tomie is offline
Old 09-22-2007, 02:01 PM
  #647
hemi426's Avatar
The 3200 will fit, but only with the sockets towards the front end of the car, otherwise the upper deck is in the way for the "+"-plug.
hemi426 is offline
Old 09-22-2007, 02:06 PM
  #648
Tomie's Avatar
Thanks!!
Tomie is offline
Old 09-22-2007, 06:52 PM
  #649
Xanavi_R34's Avatar
Originally Posted by nikkiesteban View Post
is the 1k spool is for 05ms? im planning to get one.
nope, it is for the ta05 itself only...
Xanavi_R34 is offline
Old 09-28-2007, 04:52 AM
  #650
HI_808's Avatar
Has anyone fitted their TA05MS with an Orion 4800 Li-po? Does it fit without modification to the chassis?
HI_808 is offline
Old 09-28-2007, 05:19 AM
  #651
rampal's Avatar
yep, although a little bit off-set.... crappy blackberry pictures:
3200
4800
need to use tape, and some foam on the upper chassis holders (the 'T's that holds the upperdeck with the centre bulkhead) but that's it.
rampal is offline
Old 09-28-2007, 06:14 AM
  #652
slammin's Avatar
Trader Rating: 88 (100%+)
What do you guys think about the MS compared to the MRE?I sold my MRE and considering on getting the MS for next years parking lot racing season. Does the car work good for outdoor racing?
slammin is offline
Old 09-28-2007, 03:57 PM
  #653
HI_808's Avatar
Thanks rampal. I may move to Li-po in the near future, so I wanted to be sure if the "standard" Orion packs would fit in the 05MS.
slammin, the guys who post on this thread that have MSXXs are reporting that lap times are very similar between that car and the TA05MS. Since the TA05MS has a more forward mounted motor, it can enter corners taking a sharper line, but it also reacts a little slower because it requires more weight transfer to turn. I've also noticed that it is very stable under braking, which might be due to the longer rear belt and shorter front belt than conventional designs.
I guess it would come down to your own preferences, the track, power available, and etc. Also, the TA05MS will probably lack some rear traction in comparison to the MSXX because of the forward motor position, but I personally don't have any problems with having too little rear wheel traction.
HI_808 is offline
Old 09-30-2007, 05:38 PM
  #654
Trader Rating: 118 (100%+)
Just picked up my TA05MS...
Going to run a 10.5 Novak brushless motor.
Anyone have an idea on the spur/pinion I should be using for a small/medium track?
Chris Furman is offline
Old 09-30-2007, 10:58 PM
  #655
HI_808's Avatar
I've been using a 44 tooth pinion with the stock spur (5.36 FDR) with the Novak 10.5 SS. On a large track, I'd think even a 5.0 FDR wouldn't be unreasonable. Sometimes I do go up to maybe a 5.5-5.7 FDR for very small courses with this motor.
HI_808 is offline
Old 10-01-2007, 06:35 AM
  #656
slammin's Avatar
Thanks hi-808 I think I will see how my friends runs and go from their.I can run my tao5r the last two races.I my have to get one and build it the winter.
slammin is offline
Old 10-02-2007, 02:10 AM
  #657
rays_tt's Avatar
Trader Rating: 26 (100%+)
Thought I'd share a picture of my TA05MS
Yet to get a proper run on the track, but tomorrow will be its first.
rays_tt is offline
Old 10-02-2007, 03:20 AM
  #658
Anyone try 90t/41t combo with their brushless setup?
Old 10-02-2007, 09:15 AM
  #659
Hebiki's Avatar
thats 4.94.. that seems a little too much for a 10.5. you might be able to get away with that on a 13.5 on a larger track. not sure about a 10.5 though?
Hebiki is offline
Old 10-02-2007, 09:22 AM
  #660
Tomie's Avatar
One of the guys from the local track run it 5.5 w/10.5BL..
Tomie is offline
