Like Tree2Likes
Tamiya TA05MS
Old 09-11-2007, 10:05 PM
  #601
Xanavi_R34's Avatar
Originally Posted by nikkiesteban
is there a full set of titanium turnbuckles and full set of screws for 05ms? the steel aren't good.
there is a set of ti screws for 05ms bro... But unfortunately, we dont have it here yet locally... But RC Champ has it...
Xanavi_R34 is offline
Old 09-11-2007, 10:16 PM
  #602
nikkiesteban's Avatar
i see.. thanks.
guys, any news about 05ms joining big races...
nikkiesteban is offline
Old 09-12-2007, 01:03 AM
  #603
rampal's Avatar
for turnbuckles,you need these (MSX MRE ones):
2520043 (3x42mm) 2 units
9805929 (3x32mm) 4 units
9804234 (3x23mm) 1 unit
cheers,
al
rampal is offline
Old 09-12-2007, 01:29 AM
  #604
Hey there
Last weekend i drove my first test and i have to say at that 05MS is a excellent carpet car
Cruisaaja is offline
Old 09-12-2007, 03:37 AM
  #605
cheers,
al
thanks al..
Old 09-14-2007, 04:34 PM
  #606
AWK
AWK's Avatar
We were talking about this car at Tamiya today and saying how the name "TA05MS) is very deceiving since this seems like more a TRF416 car than a TA05 since it shares virtually nothing with the TA05.
I just got mine built and was wondering a few things:
1) is sanding and gluing the chassis necessary and why
2) do I need the 46mm swing shafts to run the spool
3) what is the IDR on this car?
3) what is a good starting gearing for a 19t Checkpoint with this car
AWK is offline
Old 09-14-2007, 04:47 PM
  #607
Trader Rating: 32 (100%+)
Hey Andrew,
Definitely glue the chassis, at least just the bottom piece. Even glued, I took a small piece out of the back of the chassis this weekend.
48mm swing shafts clear the spool.
IDR is 2.25, same as TA05.
19t gearing... you're on your own!
ittjv is offline
Old 09-14-2007, 05:02 PM
  #608
HI_808's Avatar
The 46 mm swingshafts aren't necessary, but they can reduce the chatter and possibly increase your steering angle depending on your settings.
HI_808 is offline
Old 09-14-2007, 05:10 PM
  #609
AWK
AWK's Avatar
Jose, I might have to get a step by step guide how to glue the chassis as I have never done it before. You just glue a bead around the edge of the chassis? What does this do for the chassis?
AWK is offline
Old 09-14-2007, 05:11 PM
  #610
Hebiki's Avatar
Trader Rating: 26 (100%+)
5.6 for the checkpoint at the Tamiya track (if its wide open, Reedy style).
you need to bring that 05MS to BCR tomorrow. there'll be 3 of them running in the 13.5 class
Hebiki is offline
Old 09-14-2007, 05:23 PM
  #611
Yup, that's all I've ever done. Just use the tip of the glue bottle to smear it on the edge of the chassis or wet a cotton swab with crazy glue and apply it that way. I guess the chassis is made up of layers of carbon fiber and you're trying to prevent it from peeling.
And like Chris said, come on out to BCR this Saturday!!! You'll appreciate the grip. I think David J. said he was coming out this Saturday as well. Or was it Sunday?
ittjv is offline
Old 09-14-2007, 05:33 PM
  #612
AWK
AWK's Avatar
I will try and get out to BCR next weekend once I figure out how this car works and what I am going to run in it. I might make the jump to brushless and hit 10.5 or 13.5 novak once this 19t burns out.
AWK is offline
  #613
Hebiki's Avatar
i found Q-tips was the easiest. i take the tip..and tighten up the cotton with my fingers (twist inbetween your fingers). then apply it to the chassis edge.
some people then go back...sand it with some 600 sand paper..and do it again. it gives it that shiny look.
Hebiki is offline
Old 09-14-2007, 05:34 PM
  #614
Hebiki's Avatar
i have 3-4 reedy quad 19Ts i can sell you. these were the ones i had from Reedy.
Hebiki is offline
Old 09-14-2007, 07:08 PM
  #615
AWK
AWK's Avatar
Are you running the 2 or 3 hole pistons in the shocks? I just noticed I don't have any 2 hole pistons like I run usually with Tamiya 400wt oil.
AWK is offline
