Like Tree2Likes
Tamiya TA05MS
Old 08-26-2007, 07:41 PM
  #481
doriftu's Avatar
im planning to get the TA05MS and i read on Tamiya site stating that pinion gear will not be included in the kit.
question is what pinion size should i be looking at? car will be used for drifting and medium size track. thus, i prefer a more 'torquey', low FDR ratio. motor will be 23T or a BL equivalent (13.5T).
what about high FDR ratio? what pinion should i use then?
btw, has anyone here ran the Xray T2R and TA05MS for comparison? any personal reviews?
sorry for the many questions as i need to know more before spending on my next kit... thanks!
doriftu is offline
Old 08-26-2007, 08:42 PM
  #482
E-clip's Avatar
Trader Rating: 39 (100%+)
Default internal gear ratio
Hi all just wondering what the internal gear ratio is for a standard TA05ms is??
E-clip is offline
Old 08-26-2007, 09:24 PM
  #483
HI_808's Avatar
The internal ratio is 2.25 - the same as the regular TA05.
HI_808 is offline
Old 08-26-2007, 09:37 PM
  #484
Xanavi_R34's Avatar
There is a pinion included in the ta05ms, 25t 0.4...
If you're just going to drift the 05ms with a 23t motor, and a average track, I suggest you start with 6.5 FDR and start from there... Check your motor if it is getting very hot, if it does, then remove 1 tooth, but if not, you could add one more tooth but if you're happy with the FDR, then stay with it...
Xanavi_R34 is offline
Old 08-27-2007, 01:43 AM
  #485
nikkiesteban's Avatar
i already got the screw offffff.. i used cutting disc. small cutting disc..
nikkiesteban is offline
Old 08-27-2007, 02:32 AM
  #486
Xanavi_R34's Avatar
what's a cutting disc???
Old 08-27-2007, 05:03 AM
  #487
here take a look.. i made a pattern(negative pattern) to the head of the screw.. and screwed it out..
exactly like this one.. i used a small disc so it will not hit the chassis..
Old 08-27-2007, 05:42 AM
  #488
Xanavi_R34's Avatar
I want to buy one like that... That the machine itself but the disc only... Where did you get yours???
Old 08-27-2007, 07:50 AM
  #489
actually the machine is not mine.. i have a friend who has a dental clinic.. he also have that machine because he's using it to make pustisos.. heheheh
Old 08-27-2007, 07:56 AM
  #490
Xanavi_R34's Avatar
I juts noticed my typo... What I meant was not that machine but the disc itself... Where did you get yours??? (Not the machine)
Old 08-27-2007, 08:05 AM
  #491
he also have the discs... small discs specially for making pustisos.. try looking at hardwares.. they might have those small discs..
http://images.google.com.ph/imgres?i...icial%26sa%3DG
take a look...
Old 08-28-2007, 07:18 PM
  #492
Xanavi_R34's Avatar
Hey guys, anoyone run spool on their 05ms??? Could someone give info about them instead of the standard oneway??? I'm going to run 23t and mod... TIA...
Old 08-28-2007, 10:19 PM
  #493
Nope. But soon i`ll start carpet testing with my 05MS, finally
Cruisaaja is offline
Old 08-29-2007, 01:42 AM
  #494
HI_808's Avatar
I've been running my TA05MS with a spool lately. Compared to equipping your car with a one-way, you have to tune the car for the opposite effect. You need to make it dive a lot more going into corners whereas with a one-way, you need far less dive.
I changed a whole bunch of things from the standard setup, but I think my setup can still be improved a little more. I am just going to have to do a little experimenting. So far, with a spool, I am using:
inner upper camber link spacer: 2 mm (front and rear)
rear outer upper camber link spacer: 0.5 mm
inner upper camber link position: 3 (front), 2 (rear)
springs and damper: yellow, 40 wt., 3 hole piston all around
suspension mounts: B, XA (front); A,D (rear)
sway bar: red all around, tight rear, loose front
wheel spacers: 5 mm hub + 1 mm spacer all around
camber: 1.5 degrees all around
front toe: 1 degree
upper damper position setting: 3 (front), 3 (rear)
lower damper position setting: 3 (front), 3 (rear)
ride height: 4.5 mm (front), 5 mm (rear)
rebound stroke: 3 mm (front), 2.5 mm (rear)
Edit: forgot to mention that I am currently using a Novak GTB + 10.5SS motor with a 105 spur and 44 tooth pinion at the moment. The GTB is mounted to the rear of the motor.
HI_808 is offline
Old 08-29-2007, 03:02 AM
  #495
rays_tt's Avatar
Trader Rating: 26 (100%+)
Sorry if this questions has been answered already, but how big is the spur that comes with the kit? and also what pitch is it?
Oh and 1 more thing, whats the internal drive ratio?
Thanks.
rays_tt is offline
