Old 08-26-2007, 04:25 AM   #466
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
guys i have a very irritating prob.. my screw got stripped.. and i cant take it out.., its a counter sunk screw... any suggestions?
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 08-26-2007, 05:39 AM   #467
Xanavi_R34's Avatar
where???
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 08-26-2007, 05:50 AM   #468
Originally Posted by Xanavi_R34 View Post
where???
at the chassis... the screw.. the flat heads...
Old 08-26-2007, 06:01 AM   #469
Xanavi_R34's Avatar
under??? What part of it???
TAMIYA TRF416
Old 08-26-2007, 06:10 AM   #470
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
as far as i know the first TA-05 have that stripping screw problem did'nt know that the MS also have the same problem BTW is the MS already using the hex head type of screw
nikki if you have a Dremel or a small electric drill try to drill it out using one of the bits of the drill if unsure better take it to your nearest LHS and let them do it
buboy28 is offline   Reply With Quote
Old 08-26-2007, 06:35 AM   #471
buboy and xanavi.. its the screw of suspension mountings.. the suspension block i think.. its the bottom screw that got stripped. both screw for block 1B in front and 1D at rear.. .
this is so annoying maybe i didn't noticed that i tightened it too much..
BTW after all.. i won here in our race.. stock silver can..
Old 08-26-2007, 06:40 AM   #472
buboy28's Avatar
well Congratulations on the win no worries it can be remedied
Old 08-26-2007, 06:54 AM   #473
Xanavi_R34's Avatar
I had that problem... What I did with mine, lets now put it in your case, 1D at the rear, right you said, you only stripped one screw, so remove the other one that is not stripped (remove everything at the rear, bulkhead, where the ball diffs are) then turn the block suspension mount itself (where it will unscrew the screw ha). Then you'll just noticed it is already unscrewed. then just simply remove it with the screw hex driver or by finger(s).
With the two stripped hex countersunk, I drilled a hole right through the center of the screw (only the other one ha, then after that, you can just do the one stated above), I used the tamiya driller with just the right mm (it should not touch the hole where the screws usually goes, if you get what I mean... I think 2mm driller will do... Then after that, get something that will fit tight enough so that you could turn the screws and unscrew it...
Hope this will do and hope you understand... Hahah...
TAMIYA TRF416
Old 08-26-2007, 07:02 AM   #474
both screws for each suspension blocks are stripped.. hehehe..
i will try it tomorrow.. 2mm drill bit and only the center should be drilled?
Old 08-26-2007, 07:24 AM   #475
Xanavi_R34's Avatar
oh, is that so? So you need to screw one of the screw of each suspension mounts... Yes, the center only... Then if you cant turn the screw when you put something in side the drilled hole, try making some rough edges inside the hole so that it will bite...
TAMIYA TRF416
Old 08-26-2007, 07:40 AM   #476
what screw driver should it put inside the drilled hole? i will never ever tightened it too much..
Old 08-26-2007, 07:57 AM   #477
Xanavi_R34's Avatar
I didnt use a screw driver... I used a file (the round type one) then wala, it turned without any problem... because the file itself is already rough...
Me never tighten it also after this incident happened to me... Everytime I run the kit, the screws are just tightened enough just not to unscrew itself but there are some unscrewing itself but not all the way and evry after run I re tighten them again... But if you want, try putting thread lock, little amount only...
TAMIYA TRF416
Old 08-26-2007, 08:18 AM   #478
ok.. thank you very much.. i will try it tommorow..
Old 08-26-2007, 08:30 AM   #479
Xanavi_R34's Avatar
Sure.. No problem.. Anytime... Anywhere... Anyhow... Hahaha... Report ASAP ha... What will happen...
TAMIYA TRF416
Old 08-26-2007, 08:38 AM   #480
ok thanks
Tamiya Ta05ms subaru73 R/C Items: For Sale/Trade 12 10-02-2008 07:25 PM
Tamiya TA05MS Italian racer R/C Items: For Sale/Trade 15 03-24-2008 09:53 PM
FS: Tamiya TA05MS Hebiki R/C Items: For Sale/Trade 3 02-01-2008 06:30 PM
FS: TAMIYA TA05MS ONE RUN! Chris Furman R/C Items: For Sale/Trade 13 10-20-2007 05:16 AM
TAMIYA TA05MS m3ndo5a R/C Items: For Sale/Trade 4 08-14-2007 11:24 AM
