Like Tree2Likes
Tamiya TA05MS
Old 08-15-2007, 11:13 AM
  #406
Originally Posted by Xanavi_R34 View Post
GUYS, just tried doing the 16 balls diff with a 36t diff pulley (not the wide pitch version) but it seems to be not smooth...Is it really like this or should it be like a normal ball diff that we assemble out of the box??? I followed the procedures like what it says but still, no smoothness when I turn the other side of the wheel... Anyone tried this already???
Whats seems to be problem?
I use TA05 diff pulley, 501x plates and carbide balls and it was fine.
What crease did you use? I usually do my diffs with AE diff and black crease.
TA05 pulley #51212
Cruisaaja is offline
Old 08-15-2007, 01:24 PM
  #407
Trader Rating: 32 (100%+)
Originally Posted by Hebiki View Post
no worries. after TCS nats, i'll look into it more.
im just waiting for the next race day to run my 05MS again. car ran great last sat in the 13.5 stock class.
I'm with you on that Chris. I'll see you at BCR after NATs, sporting a whole new look! Maybe I can finally close the gap a bit to you fast guys!
ittjv is offline
Old 08-15-2007, 01:38 PM
  #408
Hebiki's Avatar
Trader Rating: 26 (100%+)
not much of a gap between you and me dude. trust me.
it'll be back to regular club racing once TCS nats is done..... and i'll be using this 05MS more and more. let me know if you need a set up for the 05MS. my set up last week was pretty easy to drive
Hebiki is offline
Old 08-15-2007, 08:48 PM
  #409
Xanavi_R34's Avatar
TA05 pulley #51212
I used the grease that came with the kit of my 05ms... Can you take some pics of the inner side of your diff (16 ball version) =, I want to see how you did it... Must be clear cause the one in the tut is so bright, couldnt see that much how smooth he did it...
Xanavi_R34 is offline
Old 08-15-2007, 11:58 PM
  #410
Xanavi_R34's Avatar
Sir cruisaaja, No worries anymore sir about the 16 balls ball diff... I got it working smoothly now and there is no problem... What is bothering me right now about the diff is that when I turn the diff at one side, it is smooth then suddenly for 1 sec, there would be a sound like there is something stuck inside but not that often, only for sometimes... Opened and checked it, remove some dirts and plastic that I scraped of then tried it again, for a long time, I thought it was gone but then suddenly it came back... So do you guys think it is only a dirt or anything that I shouldnt worry about??? I just noticed it is kinda half open (the balls) so it is really prone to getting dirt inside the diff balls and diff... Am I right???
Pics will follow, just charging my digicams batteries... Hehehe...
Old 08-16-2007, 12:55 AM
  #411
I use associated black grease for the thrust bearing, and the white stealth grease for the balls. I sand the diff rings on a flat surface like glass. I do get that intermittent "heavy" feel sometimes. I just take it apart and rebuild it if that happens and it usually goes away. I also use diff seals to keep all that grime from getting into the balls. I raced about 5 races with it, and it's still smooth like new.
redbones is offline
Old 08-16-2007, 07:22 AM
  #412
Xanavi_R34's Avatar
Hey guys, just want to share the 16 balls ball diff configuration that I made... It is very smooth compared to those normal diffs that we build... As in very smooth... Like what someone mentioned somewhere, I think in the trf415 thread, it is smooth like butter...
Old 08-16-2007, 08:15 AM
  #413
Xanavi
Looks good. No enjoy your ride
Old 08-16-2007, 08:18 AM
  #414
Xanavi_R34's Avatar
Xanavi
Yeah, Sure I will... Definitely... Thanks...
Old 08-16-2007, 04:02 PM
  #415
nikkiesteban's Avatar
im a bit confused.. if you'll take a look at the manual 05ms page 12 step 22(damper assembly).. there's a 12mm O-ring(BN8) and i wonder where it should be placed? can someone help me?
its okay now.. hehehe.. i placed it inside the collar...
nikkiesteban is offline
Old 08-16-2007, 07:11 PM
  #416
ShadowAu's Avatar
Can anyone offer a performance and setup comparison of the 05MS compared to a 415MS or MSX?... what setup specs changed etc?
I am in a real bind trying to decide whether to upgrade my 415MS to an MSX or MSXX or buying a 05MS (or a HB Cyclone but thats a totally different matter)
ShadowAu is offline
Old 08-16-2007, 10:01 PM
  #417
Xanavi_R34's Avatar
ahehehe...
Old 08-16-2007, 10:09 PM
  #418
E.J. Evans's Avatar
Does anyone know how many teeth the TA05MS front and rear belts are?
Thanks!
E.J. Evans is offline
Old 08-16-2007, 10:20 PM
  #419
Xanavi_R34's Avatar
Guys, did you cut off some portion of the steering arm so that the belt wouldn't touch it or did you guys just leave it as is???
And why can't I lock the diff anymore that much, It tend to not turn anymore, it like turning on the same thread (do you get what I mean)..? What seems to be the problem??? Is it the long screw or the nut???
Thanks in advance...
Old 08-16-2007, 10:44 PM
  #420
Thanks!
No, but we agree at Chris can do that when he has extra time
