Tamiya TA05MS
#301
I know what you mean, but is it not the same when the final ratio is the same?
No matter if it is a shaft drive, or a belt drive car ?
I thought the lower internal ratio is because of that the drivetrain spins more efficient (larger pulley, less friction).
Greetings Blueman
Greetings Blueman
Yes the final is the same...what you are not understand is how quick or slow it will be reach...that is determine by the IR! The belt will determine the passes......less contact will always = equal less friction. Friction is base on contact.....More efficient is why they make Belt tension to stop belt hopping.......not contact. Tamiya has made wide pitch for less friction, less teeth on the pulley......"less contact." But this is marginal and has not proven big result in any event.
The easiest way for "you" to find out is take a Xray and what every else you are driving and Drag them.....tell us who get to the top end faster. I've done this so many times.....
Keep in mind about the "Ten Speed!"
you are the "final drive"
FDR 5.00 this is just your "Cap"
--------------- 2.25 to 1 IR Higher more work
___ ___ ___ ___ ___1.7 to 1 IR Lower less work
But believe what you want.....I have better my lap times and control the field with this conversion.......Not by the Final Drive for it has not change. Everyone always mention has much faster my cars are now.....
GOARMY.COM
AN ARMY OF ONE
#302
Then wouldn't the 36t size wide pitch pulley have the same drag coefficient as an 18 teeth pulley?
Will this conversion kit from tech do any good?
http://page6.auctions.yahoo.co.jp/jp/auction/f55778182
Is that the reason why the JRXS type-Rs is so fast? Take a look at the pulley system on that.
#303
hey guys, what alum suspension mount will I add at the rear and at the front to make it "0 degree" because right at the rear it has 3 degrees toe in but the front I don't know
but I think it also has a degree, right?
So what should I get for the rear (1 sus mount only), and same goes with the front...
#304
xanavi, did you already replaced your center pulley to much larger pulley?
#305
question, why do you want 0 deg toe in at the rear of your car? most people run at least 2deg of toe in.
front has B/A... which means you have 0.5deg of toe OUT on the front. if you change it to A/A.. it will be come 0 degs.
check the 415 thread.. there's a website for TryHard that will show you the different angles for the suspension blocks.
#306
hebiki, what is the good sarting point for front degree?
and i know the rear should be 2* to 3*
but in front i dont have any idea..
#308
another i will be running 540 silver motor, i want to get the very top speed of the motor regardless the acceleration, what gearings should i use?
#309
@nikki, Nope, I havent changed the center pulley to a wider one...
#310
i think its still sleeping in fedex station here in cabanatuan. hehehe
#311
As a guideline for you, I ran a fresh silver can in my TA05R for a little while and a 6.4 (37 tooth pinion) FDR seemed to be about the limit in the local 85+ degree day time weather with 60% humidity. After running for about 5 minutes, the motor was very hot so I didn't try to use a pinion any larger.
#313
how about the speed of your ta05r? is it fast/faster than other cars(using silver can also)?
#314
You ask why??? because the straight in that track is not as long as what these people race on in international... But here at JP raceway, the FDR usually is around 6.4 - 6.0... Right you've been there already??? If yes, meaning to say you saw the stretch and the stretch is quite long compared to your HT... But if you are going to use stock motor in your 05ms, maybe your FDR should be at around 5.5 below...
#315
not really bro... Let's say you're going to race at the waltermart track, I think the FDR you should use is around 6.7 something... But to be more safer, try to start at around 6.9 then going down... This is your starting point... btw, this is for a 23t motor ha... Not stock...
