Like Tree2Likes
Tamiya TA05MS
Old 08-08-2007, 08:54 AM
  #271
Xanavi_R34's Avatar
Hey guys, quick questions here, do I really need to remove the tires before storing the CF kit? and do I really need to place the Chassis (CF) on a flat surface like glass? TIA...
@nikki, hey did you get your kit yet???
Xanavi_R34 is offline
Old 08-08-2007, 12:12 PM
  #272
m3ndo5a's Avatar
Wanted share the conversion of my 05MS from 2.25 to 1.94 Internal Ratio. This will truely keep your belts on. I had this conversion on My MRE and it was fast....So I did the same for my 05ms....my lap time difference from my MRE and 05MS was .30 slower on the MS....I so with this conversion and working on the steering ackerman...I shoulds be faster this weekend.....
Oh and P.S. it is illegal for a vendor to charge PayPal fees to a customer! Read Paypal agreements.
Attached Thumbnails Tamiya TA05MS-mre-ta05-030.jpg   Tamiya TA05MS-mre-ta05-031.jpg   Tamiya TA05MS-mre-ta05-032.jpg
m3ndo5a is offline
Old 08-08-2007, 12:19 PM
  #273
Xanavi_R34's Avatar
is this 2.25 internal ratio to 1.94 the center gear thingy???
Old 08-08-2007, 12:23 PM
  #274
m3ndo5a's Avatar
Its what you get when you divide the Diff pullies from the layshaft pully (yes the center thingy) 35/18=1.944.....
m3ndo5a is offline
Old 08-08-2007, 12:27 PM
  #275
Xanavi_R34's Avatar
oh okay, so you call it the layshaft pulley... Thanks bro...
BTW, what brang are those gears???
Old 08-08-2007, 12:38 PM
  #276
habis's Avatar
with rear belt beeing longer on the 05MS, wha belts are you using?
habis is offline
Old 08-08-2007, 12:52 PM
  #277
Xanavi_R34's Avatar
correct me if I'm wrong, I think the rear is the one shorter...
Or what you meant by is what if the rear is longer, what belts should is he using...???
Old 08-08-2007, 01:08 PM
  #278
m3ndo5a's Avatar
They are the Kit Belts and Tamiya TRF 415 pullies. The Pullies are smaller than the 36 pullies which make it fit just right.
m3ndo5a is offline
Old 08-08-2007, 01:11 PM
  #279
Xanavi_R34's Avatar
oh okay, thanks again bro...
Old 08-08-2007, 02:48 PM
  #280
nikkiesteban's Avatar
why do you fellas want lower internal ratio?
whats the reason behind lower IR?
nikkiesteban is offline
Old 08-08-2007, 07:59 PM
  #281
for more usable ratios
oversquared is offline
Old 08-08-2007, 08:17 PM
  #282
sorry, i can't understand. I'm a bit confused.
some says that lower Internal Drive Ratio improves acceleration?
can someone explain what IDR(internal drive ratio) really do?
Old 08-08-2007, 08:24 PM
  #283
Xanavi_R34's Avatar
hey nikki, did you get your kit already???
Old 08-09-2007, 12:56 AM
  #284
competitive servo for Ta05MS?
Old 08-09-2007, 01:28 AM
  #285
Xanavi_R34's Avatar
The top 3 International Japan Racer said that the best servo is the Futaba S9251...
And this only cost at around 5,998 pesos bro... in lils...
