DIY Discharge tray >
DIY Discharge tray
DIY Discharge tray
Old 04-16-2007, 06:49 AM
Phroz's Avatar
Default DIY Discharge tray
Found this.. does anyone think this would actualy work?
http://homepage.ntlworld.com/terry.c...l/distray.html
Cheers,
Ben
Phroz is offline
Old 04-16-2007, 07:44 AM
Yes sure it works!
I have built two trays like these (did not copy intructions from that site) and they do their job well, but thing which should be noticed is that cut-off voltage is fixed due to technology to 0.7 volts and by my knowledge for example with IB4200-cells the voltage should NEVER be dropped under 0.9V/cell.
Tommi
TommyW is offline
Old 04-16-2007, 08:10 AM
Phroz's Avatar
Hrm any ways around that? different diode or resistor maybe?
Phroz is offline
Old 04-16-2007, 09:49 AM
Pat Clark's Avatar
Nope.. From what Im told there isnt any Diodes out there that cutoff at anything different... The Resistor is just the load...
Pat Clark is offline
Old 04-16-2007, 10:51 AM
Iceracer's Avatar
You'd need to find a diode with a higher forward voltage drop, say 0.9 or 1.0 volts. Pour over the spec sheets and you may find one, whether its cost effective is another question. You might even be able to find some bulk rectifiers that are in the right ballpark and test and match them, but is it worth your time?
Iceracer is offline
Old 04-16-2007, 10:53 AM
It is just the diode which controls whether a single cell is being discharged in this kind of tray.
The control-mechanism is very simple: diode has a so called 'threshold voltage' (is 'gate' open or closed) - in normal diode this voltage is around 0.7V. When the voltage of single cell drops under 0.7V - diode does not let the current go through anymore and discharging is stopped.
Tommi.
TommyW is offline
Old 04-17-2007, 07:41 AM
Phroz's Avatar
Ah ok makes sense.. have to have a hunt for diodes and see what i can find.. as far as worth the time? well half the fun is the project itself and making something that works from scratch... ah.. the good ol' days of rc lol
Thanks for the input guys!
Ben.
Phroz is offline
