Old 04-23-2007, 12:58 AM   #106
Send a message via ICQ to number_one
Originally Posted by Big B
Looks to me almost like a home built car, the diffs are from associated (pretty sure), antenna mount xray, front upper bumper xray, the hubs all the way around almost look like xray aluminum rear uprights, the upper a arm is a couple of shumacher turnbuckles, lower arms look like xray, etc...
Yes, of course some parts are using from current cars, but the suspension are fully original - there are no one part from any other car.
Of course, when the producing started, the car will looks better and all parts will be original.
There will be gearhousing from CNC Aluminium instead geaboxes from PRO4, lower upper deck, lower steering, etc. That car is just to test suspesion - we see, that it works really really good.
number_one is offline   Reply With Quote
Old 04-23-2007, 02:40 AM   #107
Will these dampers also work on bumpy outdoor tracks...
Dampers are not that critical on a carpet track where I assume this car has been tested. But it will be interesting to see it, dampers are so underdeveloped in all classes of rc cars.
moonman is offline   Reply With Quote
Old 04-23-2007, 04:01 AM   #108
it works really good )) both it has different forward-back viscosity.
Old 04-23-2007, 10:57 AM   #109
Some photos of the car from Russian National winter championship:
http://rcauto.spb.ru/forum/index.php...e=post&id=3552
http://rcauto.spb.ru/forum/index.php...e=post&id=3551
http://rcauto.spb.ru/forum/index.php...e=post&id=3550
BTW1 is offline   Reply With Quote
Old 04-23-2007, 11:41 AM   #110
RandyB's Avatar
that sounds heavy would rather see plastic
RandyB is offline   Reply With Quote
Old 04-23-2007, 04:57 PM   #111
RCSteve93's Avatar
It you tighten molded gearboxes too much, it will bind the gears. CNCing them will make them perfect so you can tighten them all the way.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 04-23-2007, 05:57 PM   #112
RandyB's Avatar
metal threaded inserts in the plastic work well too. And with shaft car gear boxes you never want to tighten them all the way. Bearings are bound to bind up
Old 04-24-2007, 03:44 AM   #113
tc3team's Avatar
Originally Posted by DOTMAN
Well heck...no wonder the car did so well. Two of the cars in that pic don't even have chassis'
Thats funny but im with Jo90 on this one, nice to see someone developing something different.
And yes, in stock you need all the sharp response you can get from the transmissions "on power loading" and shaft driven cars give that nicely
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-24-2007, 11:46 AM   #114
RCSteve93's Avatar
But if they were CNC aluminum you could tighten the snot out of them, and they wouldn't bind up. Thay way the diffs are sealed.
rm -rf /windows
Old 04-24-2007, 01:24 PM   #115
Big B's Avatar
not true, I had aluminum diff cases on my tc4 and if you overtighten them they bind the bearings
Big B is offline   Reply With Quote
Old 04-24-2007, 03:16 PM   #116
Team Tekin
TY@TEAMTEKIN's Avatar
I think aluminum diff housing will be fine. It'll make up the lost weight for not having traditional coil-over dampers and be eye candy at the same time. Car's gotta meet weight restrictions, and I bet it wouldn't if it was all plastic/cf with the type of suspension they are designing. Looking at that pic there are like 10 lead weights in the front of that thing, alloy diff housings would help. I'd rather not have to put $50 in quarters in my car to make weight, youknowwhatimsayin'?
Looks cool, can't wait to see how the damping system works!
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 04-24-2007, 03:22 PM   #117
YR4Dude's Avatar
Trader Rating: 44 (100%+)
So from looking at all the pictures and posts, I basically gather that this is a shaft drive 4WD pan car with gear reduction and independent suspension with 1/12th style grease/friction dampers. There's a custom gearbox that mounts directly to the motor shaft and does the 90deg with bevel gears to a shaft where a standard pinion mounts to drive a standard spur like a traditional shaft car. Thats a nice idea for a good "CARPET" CAR! Once is gets lumpy and bumpy outdoors, its back to the traditional shocks and suspension. Still good though, has Marty L. Petersen seen this yet?
YR4Dude is offline   Reply With Quote
Old 04-25-2007, 12:00 AM   #118
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
MMM OK,,,
burbs is offline   Reply With Quote
Old 04-25-2007, 02:14 AM   #119
TRF415boy's Avatar
100% wrong on both assumptions. 1st it's not a bevel gear that does the 90 transfer, 2nd he wouldn't be patenting the shocks if they were the same thing as used in 12th scale. I know the designer, he's a very talented engineer, and although I don't know everything that's going on with that car, I can tell you we're in for a few innovations there.
TRF415boy is offline   Reply With Quote
Old 04-25-2007, 09:23 AM   #120
YR4Dude's Avatar
Okay then is he using something like a flex drive similar to a Dremel tool for the 90? Is the dampening separate of the springs? If so, is he using leaf springs?
Feeler Thread 6X10 Pace trailer set up for Racing Flyin Ryan R/C Items: For Sale/Trade 0 09-02-2008 08:02 PM
2005 6x12 enlcosed trailer Pace work/sport IMMACULATE!! MajorWoody Other Items: For Sale/Trade or Wanted to Buy 2 03-19-2008 05:26 PM
2005 6x12 enlcosed trailer Pace work/sport IMMACULATE!! MajorWoody R/C Items: For Sale/Trade 5 11-30-2006 12:14 PM
Losi 4wd prototype + BJ4 prototype at Worlds cartmen34 Electric Off-Road 32 08-24-2005 09:13 PM
Titus Hobbies...Setting the TQ PACE! Gabe Boudreau Racing Forum 59 04-25-2005 02:21 PM
