Old 04-05-2003, 11:12 PM   #1
Send a message via AIM to M Ignacio
Default Bearing " Detergent"
Hey guys, what do you think is the best liquid/cleaner to clean your bearings with? Paragon "bath", motor spray, mineral spirits( BTW where can you get mineral spirits and exactly what is it?), or good old fashion H2O? Please let us know what liquid/ cleaner has worked best for cleaning your bearings. Much appreciated! Thnx
M Ignacio is offline   Reply With Quote
Old 04-06-2003, 12:50 AM   #2
Speedie's Avatar
Default Both are ok
Both will do the same thing flush out the dirt without leaving behind a residue. Mineral spirits is just paint thinner you can get it for a couple of bucks a galon at any hardware store. Harbor freight tools also has a refillable spray can that you can use to spray it with.
Speedie is offline   Reply With Quote
Old 04-06-2003, 08:23 AM   #3
Registered User
OB42TC3's Avatar
Laquer thinner works very good, then blast on bearing blaster with motor cleaner, then re-oil.
OB42TC3 is offline   Reply With Quote
Old 04-06-2003, 09:39 AM   #4
popsracer's Avatar
Soaking just doesn't do it.
Clean with Motor Spray in a Bearing Blaster, then I lube with Trinity Purple Royal Oil.
For my Nitro Cars, I use a Teflon based spray (heavier) through the Bearing Blaster.
popsracer is offline   Reply With Quote
Old 04-06-2003, 04:04 PM   #5
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I use the same method....but I use good old' Military Alphatic NAPTHA to clean the bearings out or PD-680 ( same stuff that the dry cleaners use to clean your clothes )
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-06-2003, 05:56 PM   #6
Send a message via AIM to ZER01
Lectra-Clean from CRC, basically it's just motor-spray. Home-Depot sells the stuff for about $5 a can.
http://www.crcindustries.com/gallery...&box=&shownew=
ZER01 is offline   Reply With Quote
Old 04-06-2003, 09:36 PM   #7
popsracer's Avatar
[QUOTE]Originally posted by proudwinner
[B]Lectra-Clean from CRC, basically it's just motor-spray. Home-Depot sells the stuff for about $5 a can.
Holy Crap!! At $5 a can, my Stock better run like a 10T after that.
Try NAPA auto parts stores for electric Motor spray anout $2.50 a can regular price, less than $2 on sale.
Old 04-06-2003, 11:17 PM   #8
i can remeber back in the day "Dans Motor spray" cost $10.00 a can. its was also the only motor spay that (at the time) would not melt plastic.
jayco76 is offline   Reply With Quote
Old 04-07-2003, 08:36 AM   #9
I used to get the same stuff at NAPA but it came in a red can and was about the same price. I wish motor-spray was cheaper. Brake-cleaner is about $2.50 a can at NAPA but I've never found "electric-motor spray" in that price range. Here's another version of "motor-spray" from NAPA at $4.29 a can, the can is smaller than the previous can I posted a few posts up(same company though).
http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
Old 04-07-2003, 08:48 AM   #10
I like to use Goof Off to clean my bearings. Works like a charm.
http://www.goof-off.com/
ARC MotorSports is offline   Reply With Quote
Old 04-07-2003, 08:51 AM   #11
popsracer's Avatar
Default 10T Motor in a can
I STILL want something in a spray can that will turn my Stock into a 10T.
I'll go to the local NAPA out here and see if I can find the stuff. I'll post the part # when I find it.
Old 04-17-2003, 07:55 PM   #12
When you guys use Lacquer Thinner, in what container do you keep it in when cleaning the bearings? You can't use lacquer thinner with bearings with shields on them, right?
Old 04-17-2003, 08:16 PM   #13
i take the bearings shake them in a pill bottle full of denatured alchol. then everyonce in a while i shake the crap out of the bottle after about an hour of doing this on and off i take an exacto knife and take all the dirt out of the sides of the bearings. once finished i lube them with trinity purple royal oil
jiggamacdaddy is offline   Reply With Quote
Old 04-18-2003, 07:08 PM   #14
Just wondering what kind of container you use when cleaning your bearings with lacquer thinner because I used a plastic container........let's just say that the plastic container didn't look the same!!!! LOL!!
Old 04-18-2003, 09:23 PM   #15
The denatured alcahol dosen't do to much to the plastic but the laquer thiner thing will eat the crap out of the plastic.. as for what type of containter i use to clean the bearings a pill bottle works great
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
Bocca Bearing "Green Seals" Trixter Electric Off-Road 4 02-26-2006 08:26 AM
