Old 04-12-2007, 05:21 PM   #1
Default Orion V2 brush tubes?
ok i pulled my orion v2 down pulled the armature out brushes springs and even the little circuit board the brushes seem bout 3 mm shorter than a new pair is this useable? im a budget racer so im generous in the sense of if it runs its good enough.
only thing i wanted to do was pull the brush tubes out to clean around em, can and how do i do this?
cheers, Josh P
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 04-13-2007, 10:58 PM   #2
any one know how to get em out?
please?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 04-13-2007, 11:59 PM   #3
John Doucakis's Avatar
I am not sure if I understood correctly but you want to dissasemble the brush tubes?
This is completely wrong. The brush tubes have been glued to the alum endbell with great precision in order to have them perfectly alligned to the armature.
Even if the brush tubes start to move, then your endbell is no longer good.
You don't need to clean them externally, only internally. You may do that by using some paper or cloth with clear alchohol, or for even better results you may use a little polishing cream to make them smooth and shiney.
The same you can do to your used brushes. You can use some polishing cream to clean their surface, thus maximizing the current flow as they will have better contact with the inside of the brush tubes.
John Doucakis is offline   Reply With Quote
Old 04-14-2007, 12:56 AM   #4
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
are u serious???? i can take like mothers wax and put some on a pipe cleaner and go through the brush houses that the brushes sit in and that will increase performance?
BlackedOutREVO is offline   Reply With Quote
Old 04-14-2007, 01:54 AM   #5
Superkarter's Avatar
Yes because most of the current flows through tht tubes into the brushes
so increasing the conductivity of the tubes will increase performance
Superkarter is offline   Reply With Quote
Old 04-14-2007, 02:08 AM   #6
ShrekNZ's Avatar
I think they are referring to polishing using metal polisher NOT wax which will leave a residue probably decreasing the conductivity of the brush tubes.
ShrekNZ is offline   Reply With Quote
Old 04-14-2007, 02:21 AM   #7
I thought it was obvious I was referring to metal polishing cream.
Nothing must be left on the surface of either the brush tube or the brush itself.
The objective is to have as much contact between the copper tubes and the brush surface.
This is also one of the reasons that round, tubular brush hoods and brushes perform better than the conventional square ones. It is easier to manufacturer the round tubular brush hoods with tighter tolerances and thus have maximum contact between the brush hoods and the brushes.
This is also the reason that you must pay attention to keep both brush surfaces and brush tubes always clean, so they maintain maximun conductivity with each other while they remain smooth in their in-out movement, without binding.
Old 04-14-2007, 12:06 PM   #8
ohhh ok then, i guess i will stick to rubbing alcohual on a pipe cleaner lol, it gets the stuff out of the brush hoods
Team Orion brush hirosaki Electric On-Road 1 01-02-2008 10:44 PM
For Sale: Brush cutter, serrator, motor tubes, timing jigs. Kraig R/C Items: For Sale/Trade 1 12-26-2007 01:47 PM
Orion V2 brush tubes thecrow2k Electric On-Road 0 04-12-2007 04:36 PM
Orion Brush Lot $30 Shipped BritRacer R/C Items: For Sale/Trade 2 04-11-2006 11:50 AM
Orion Revolution Brush Break In RCNitroDude999 Electric On-Road 8 02-11-2005 07:54 AM
