Old 04-04-2003, 05:53 PM   #1
Default Motor sparks
why does my P2k2 pro sparks on one brush but nothign on the other ?
zoombie is offline   Reply With Quote
Old 04-04-2003, 08:09 PM   #2
Steevo's Avatar
I would check that your brush is not hanging up slightly. It could be that the brush hood is dirty and the brush is hanging up. Also check the braided shunt to see if it is caught. Sparks usually occur if the brush is "bouncing" or not making good contact with the comm. If you have fitted a weaker spring on the negative side then the brush may be bouncing.. Check the condition and wear on the brush compared to the other side...... These are just some suggestions.
I am no expert but I would have a look at these possibilities.
Steevo
Steevo is offline   Reply With Quote
Old 04-04-2003, 08:38 PM   #3
popsracer's Avatar
Default Re: Motor sparks
How long has it been since the Com was cut? An out of round Com will "Spark" and cause glitching (besides bad performance).
It might be a good idea to replace the brushes at this time also.
popsracer is offline   Reply With Quote
Old 04-05-2003, 03:33 AM   #4
have no idea how long since the comm was last cut as it was a second hand motor...
Old 04-05-2003, 04:49 AM   #5
sosidge's Avatar
A small amount of sparking is normal, a large amount means it's time for a clean and rebuild.
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Sparks from motor D_o_S Electric On-Road 4 04-13-2006 03:45 PM
speed+metal=Rosstertail of sparks good idea or bad idea? TC3Racer87 Electric On-Road 6 11-13-2004 09:25 PM
Sparks visible in motor - What the ??? rctoyguy Electric On-Road 11 07-09-2004 04:10 AM
Zapped some cells, made SPARKS! Gutter Ball Electric On-Road 25 04-05-2004 07:22 PM
