Old 04-10-2007, 07:49 AM   #1
B4Bandit's Avatar
Default Motor Burn Out
I burnt out one of my CO27 motors recently
Would it be fine to just replace the armature or should I get a whole new motor... It was quite a good motor
Cheers.
B4Bandit is offline   Reply With Quote
Old 04-10-2007, 08:27 AM   #2
timmay70's Avatar
Cheers.
If the motor ran very well, it would probably be a good idea just to replace the arm. You will probably find that it has simular performance to what it had originally. If you over heated the can in the process of killing the motor, it would also be a great idea to re-zap the magnets, too. Heat kills magnets.
Be sure to clean everything really good before reassembly. I like to use dish detergent to scrub things clean when doing full re-build. Use a com stick to clean out the brush hoods, too. Most of the power gets transferred to the brush through the brush hood, not those little tiny shunt wires that stick out the back of the brush.
If you don't want to complete the rebuild yourself, motor builders/tuners like Team Kwik will complete the full task for you for a minimal fee. Definately worth the price of admission.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 04-11-2007, 01:12 AM   #3
B4Bandit's Avatar
Cheers mate. I'm happy to do the rebuild myself... never heard of the dish detergent approach!!! Might give it a try on the can...
Old 04-13-2007, 02:25 AM   #4
RC TT01D's Avatar
How'd you burn it? And the detergent works!
RC TT01D is offline   Reply With Quote
Old 04-13-2007, 07:13 AM   #5
B4Bandit's Avatar
I put it in my BJ4 without checking the gearing chart I ran it with a 25 tooth pinion!!! I normally run a Novak 6.5.....
Motor Burn Out B4Bandit Electric Off-Road 3 04-18-2007 09:42 AM
Burn Rubber? BayArea101 Electric On-Road 15 01-22-2007 05:22 PM
Almost burn myself BBSGS4 Electric On-Road 11 06-26-2004 06:40 PM
Too much motor burn in? Cole Trickle Electric On-Road 8 06-02-2002 10:52 AM
lrp v7.1 burn up monsooni1 Racing Forum 8 01-17-2002 03:40 PM
