Old 04-06-2007, 11:26 PM   #1
Trader Rating: 2 (80%+)
Default CE Turbo 35 GFX Help Needed for Setup
Ok just got a Turbo 35 GFX Charger I am charging the following packs:
3500mAh 6 Cell Packs
4200mAh 4 Cell Packs
4300mAh 4 Cell Packs
1600mAh 4cell Spec Packs
Can some one help me with optimum settings for charging screen discharge screen and cycle screens for each of these packs. I figure a 6 amp charge and 30 amp discharge would suffice however would be interested in what other setting need to be.
gunlocators is offline   Reply With Quote
Old 04-06-2007, 11:28 PM   #2
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
for the first three plug it in and hit start already set up for mimh 6a , the discharge cycle is already setup for 30amps, and for the 1600 pack, make a new profile
Caster Racing USA Dirt Oval
Hyperdrive
Tekin
THD Custom R/C Products/Team Holy Rollers/Team Terribles
loopedout is offline   Reply With Quote
Old 04-07-2007, 12:01 AM   #3
Cool I figured it out also downloaded and printed 62 page manual. Do you think it is worth sending it in to get firmware upgraded from the 1.4 to 1.6 ?
Old 04-07-2007, 05:10 AM   #4
volracer's Avatar
Send a message via ICQ to volracer
I did not see in your original message what type of battery you are chaarging. NiMH take a lower pesk detect than NiCD. Refer to the manual for help. I have different setup on my GFX for the different types of batteries.
volracer is offline   Reply With Quote
Old 04-07-2007, 09:39 AM   #5
jdearhart's Avatar
Trader Rating: 15 (100%+)
On your Spec packs, if you are running outside, charge at 5 amps with a .03 peak detect. For carpet, charge at 7 amps with a .03 peak detect. Discharge at 15 amps with a .90 per cell cutoff (3.60 volts.)
You also need to get a single 1157 automotive bulb, and discharge the battery with that after discharging it on the GFX. Take the bulb off as soon as it starts to go out, and go straight to charging.
Hope this helps!
Jack
jdearhart is offline   Reply With Quote
Old 04-07-2007, 12:17 PM   #6
NiMH oneverything except spec packs
Help needed for GM V8 esc setup jawa Electric On-Road 3 07-31-2006 02:05 PM
PMB Setup System needed Packfan R/C Items: Wanted to Buy 0 07-05-2005 03:16 PM
Help needed on brushless setup ah_liang Electric On-Road 0 04-10-2005 09:08 AM
setup board needed ntc3freak R/C Items: Wanted to Buy 0 10-08-2004 04:54 AM
Needed Turbo 35 Stealth 29Dennis R/C Items: Wanted to Buy 3 01-13-2004 02:08 PM
