Old 04-03-2003, 04:24 PM   #1
Default Gm V3r
Do you think i could run a 17 x 2 on my GM V3R with 6 cells?
rcracer123 is offline   Reply With Quote
Old 04-03-2003, 04:51 PM   #2
i think that speedo is rated for 18 turns if im not mistaken you would probaly be ok but if anything happened it would void the warranty. it would depend on the amp load that esc can handle....
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 04-03-2003, 04:54 PM   #3
gotcha, here are the specs, if anyone can tell me just by reading them that would be great, because i know i sure can't!
Motor Load: 18 turn
Continuous Current: 24A
On Resistance: .003 ohm
Pulse Frequency: 500Hz
Input: 4-10 cells
it says it could handle 10 cells, so does that mean it could handle 10 cells on an 18 turn? if so i think 6 cells on a 17 x 2 shouldn't hurt it.
Old 04-03-2003, 09:14 PM   #4
After a few full throttle run your ESC will become very hot.
Chances that you will smoke it.
According the manual of a SX9 it can handle a 8 turn.
But after a few runs it totally stopped.
Overheating protection was on !
I don't know if a GM V3r has this protection.
Awesome is offline   Reply With Quote
