Schumacher Mission not fast enough? >
Old 04-03-2003, 12:11 PM
Default Schumacher Mission not fast enough?
Hey guys,
I race at a small carpet indoor track, with about 2/3 straight and 1/3 corners. My Schumacher mission just can't keep up woith the other guys around the corners, because of it's loss of acceleration, and slips behind a bit on the straights too, can any of you tell me what pinion gear, spur or anything else to buy to make it faster and have more acceleration. Bear in mind i am running the 20t pulley, 86t spur gear, 25t pinion gear. Everything else is just standard.(p2k2 motor, only allowed 27turn stock)
Cheers
jackv202 is offline
Old 04-03-2003, 12:41 PM
Ian S's Avatar
Not seeing the track and never running stock this is a guess but id say that your over geared, i run 26/86 and 20 tooth pully with a 12 turn at ashby and that has a looong straight. You might get more specific answers if you ask in "schumacher corner" theres some things you can do to free the drivetrain up a little if you havnt allready.
Ian S is offline
Old 04-03-2003, 12:49 PM
Regional Moderator
Darkseid's Avatar
Default Re: Schumacher Mission not fast enough?
Originally posted by jackv202
Hey guys,
My Schumacher mission just can't keep up woith the other guys........can any of you tell me what pinion gear, spur or anything else to buy to make it faster...
The Mission is a good car, that can hang with anything else on the track. Not all answers to being faster can be found with simply buying stuff.
Just a thought.
Darkseid is offline
Old 04-03-2003, 12:51 PM
Cole Trickle's Avatar
A general thumb of rule about gearing: At around 3/4 of the longest straight, your car should hit max. speed. If the track are without too many sharp turns, you might go one tooth up on the pinon. For technically tracks, go one tooth down.
Cole Trickle is offline
Old 04-03-2003, 06:23 PM
adrian's Avatar
what packs you using? are they in good condition? cos thats what makes you fast......
adrian is offline
Old 04-04-2003, 06:46 AM
Default Schumacher mission not fast enough?
i am running sanyo 3000's and 3300's, how should i charge these on a timed charger though?
Cheers.
jackv202 is offline
Old 04-04-2003, 07:15 AM
I would try running the 17 tooth pully, it should allow the car to get up to speed a little faster. I would have to agree with Ian that it sounds like you are a little over geared, that is about the same final drive ratio that I run on our larger out door tracks. Try running a final for 7.0 - 7.2 range.
LarryPryor is offline
Old 04-04-2003, 09:11 AM
Brian McGreevy's Avatar
No I wouldn't suggest running teh 17 tooth pulley. I run on a fairly small track (70x40) and when I ran a mission the 17 tooth pulley was just downright slow. Yes, the drivetrain does spool up faster, but it spools up faster, and if you don't have enough power already, the car will look even slower. Trust me, I know from experience, once i changed to the 20 tooth the car was much faster. So you probably have slow motors, old/bad batteries, a non-free drivetrain, or you're simply overgeared. Just my 2 cents.
Brian McGreevy is offline
Old 04-04-2003, 09:15 AM
Are they stick packs? And you're charging them on a timed charger...uh oh not good. That is probably why. You don't get a full, good peak with timed chargers. If you can afford it, i would suggest investing in a good peak charger with varying charge rates and peak detection for NiMH cells, like the Reedy Quasar (or Quasar Pro depending on the amount of cash you have).
Old 04-04-2003, 10:17 AM
sosidge's Avatar
GET RID OF THE TIMED CHARGER
You'll never get a good charge unless you invest in a peak detect model (prefereably a quality version with adjustable charge rate and delta).
sosidge is offline
Old 04-04-2003, 10:23 AM
Yep, listen to Sosidge and Axiom about the charger.
Old 04-04-2003, 11:29 AM
ottoman's Avatar
I have been running two Missions (one in stock and one in mod) since they first came out. I have switched between the 17 and 20 tooth pulleys many times and I cant say I ever noticed much of a difference. If your looking for a big improvement I would look somewhere other than the pulley size. Motor and gearing, battery, corner speed and freeing up the drivetrain are all more important.
ottoman is offline
Old 04-04-2003, 11:57 AM
2 things. Sounds overgeared, but can't be totally sure without seeing the track, but for a general indoor track sounds high. secondly you really aren't going to get anywhere near full power with a timed charger. I know others have said the same, just ehcoing it!!
MattW is offline
