1/10th Pan Car: CORALLY C10X >
Old 04-05-2007, 04:32 AM
paul73rc's Avatar
Trader Rating: 5 (78%+)
Default 1/10th Pan Car: CORALLY C10X
Hi everyone,
I have recently purchased a Corally C10X and I want to get high speeds out of it. I want to run a Epic 10X2 however I don't know what are the best gears to use for high speeds.
What gears should I use???
Pinion? (Teeth)
Spur Gear? (Teeth, Pitch)
Kind regards, Paul
paul73rc is offline
Old 04-05-2007, 05:23 AM
losi nut's Avatar
Try a 44 t 64p pinion and a 93t 64p spur, should give a fairly fast speed with a 6 cell, don't know how long your motor will last , but it'll be moving when it does start leaking smoke
losi nut is offline
Old 04-06-2007, 10:08 PM
paul73rc's Avatar
Hey, I tried what you said but the motor blew up in 2 minutes. Only joking. lol. As if I would run those gears. Nice joke. At the start I thought you were serious but then I realised.
I am actually running a 48p 86t Spur and a 48p 16t pinion and that runs quite good.
Thanks anyway
paul73rc is offline
Old 04-09-2007, 11:52 AM
Moderator
Pro ten Holland's Avatar
run the 10x2 at 3mm timing, and a rollout of around 35mm.
Pro ten Holland is offline
Old 04-10-2007, 02:12 AM
paul73rc's Avatar
How do I do that?
paul73rc is offline
Old 04-12-2007, 10:11 AM
Moderator
adjust the motor's timing so it's 3mm from zero.
have a look at www.gearchart.com
on that web page you can create gearing charts, telling you the number of mm the car travels when the motor turns 1 time.
You can adjust this number by gear selection, and rear tire diameter.
Normally you start with a full size tire (diameter around 63 mm) and a certain rollout that suits your motor, the motor's timing, the track you run on and your driving style.
When your tires wear down, the rollout number changes.
By adjsuting your gearing, you can keep the same rollout and motor performance.
just have a try, and report back if you can't get it figured out.
Old 04-12-2007, 10:36 AM
Kevin Boyle's Avatar
Does anybody still make 1/10th scale GTP pan car bodies like in the old days?
They would be super fast with todays technology
Later
Kevin Boyle
Kevin Boyle is offline
Old 04-12-2007, 11:41 AM
Moderator
https://www.ssl-stormerhobbies.com/c...s&pn=PFM140722
https://www.ssl-stormerhobbies.com/c...=ns&pn=ASC6128
https://www.ssl-stormerhobbies.com/c...c=ns&pn=MCA123
https://www.ssl-stormerhobbies.com/c...c=ns&pn=MCA146
Old 05-01-2007, 06:51 PM
Default gO fAST
GET RID OF THE BRUSHED MOTOR GET A BRUSHLESS SYSTEM WITH SINTERED ROTOR...END OF STORY....
Hanz Grueber is offline
Old 05-01-2007, 07:38 PM
losi nut's Avatar
losi nut is offline
Old 05-02-2007, 07:42 AM
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
THere is a forum for pancars...this discussion should go there....
yyhayyim is offline
